clutch master cylinder
Old Nov 22, 2004 | 07:39 PM
old_school_dohcvtec's Avatar
Default clutch master cylinder
how do you know if your clutch master cylinder is defective or leaking?
my gears are starting to grind and i know that my slave cylinder is leaking, but im not sure if i should change the master as well?
Old Nov 22, 2004 | 07:44 PM
..::91TEG-G2::..'s Avatar
Default Re: clutch master cylinder (old_school_dohcvtec)
could be your syncro's going bad..
but i dont know how to check the cluck MC
posjr's Avatar
Would be best to change both but just change whats leaking and take it from there.
Old Dec 1, 2004 | 08:23 PM
B18Tahtaras's Avatar
push on the clutch while someone is watching the reservoir. If the fluid goes up and down while the pedal is being pumped its bad... but thats only if its really bad. as far as your gears grinding, clutch master cylinder is a common cause. good luck
Old Dec 1, 2004 | 08:33 PM
JustROLLIN's Avatar
Another good way to tell is when you press the brakes. Typically a bad master cylinder will slowly sink to the floor while pressing the brakes instead of stopping at a certain point.
Old Dec 1, 2004 | 10:12 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (JustROLLIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustROLLIN &raquo;</TD></TR><TR><TD CLASS="quote">Another good way to tell is when you press the brakes. Typically a bad master cylinder will slowly sink to the floor while pressing the brakes instead of stopping at a certain point.</TD></TR></TABLE>
That's the break MC, not the clutch MC
Old Dec 2, 2004 | 04:26 AM
JimBlake's Avatar
Default Re: (marsbike)
An internal leak in the clutch MC is pretty much like in the brake MC, but here's how you can check...
Open that rubber boot over the throw-out fork. Have someone pump the pedal, then hold it down. If the MC is leaking back into the reservoir, then the throw-out fork will slowly move back towards the slave. While holding down the pedal, the T-O fork isn't supposed to move.
Old Dec 2, 2004 | 10:51 AM
dc2drifterx's Avatar
If you are replacing one, I would do both. You may want to make sure your tranny fluid level is good and bleed your clutch lines before you replace parts.
siregcivic
Oct 16, 2005 07:55 PM
Utilitarian
Jun 17, 2005 11:49 AM
TurblowR
Mar 28, 2005 06:26 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
3rdGteg
Nov 5, 2002 01:21 PM
