turbo traveling
Old Nov 22, 2004 | 07:26 PM
xcountrirunr's Avatar
Default turbo traveling
I recently boosted my 02 accord and I'm wondering if its safe to drive from college to home with the car, the trip is about 500 miles and I'll make it in one day. Setup is on a 4cyl stock, gt28rs spools by 3200 with me on 8lbs. My setup includes a fuel pump, fpr, and 440 injectors. Is it safe to make the drive, and should I take precautions to stay out of boost by crusing at or below 2500. Thanks for any help
b16sedan's Avatar
Default Re: turbo traveling (xcountrirunr)
You could cruise at 4500 RPM's at low throttle and you wouldn't make boost because boost is a function of load.
Old Nov 22, 2004 | 07:30 PM
Mr.DC2TurBo's Avatar
if u stay out of boost then you're fine.
Old Nov 22, 2004 | 07:43 PM
m R g S r's Avatar
Don't beat on it too much, I know the highways are tempting, but stay off the throttle.
Old Nov 22, 2004 | 07:44 PM
oxSLEEPERxo's Avatar
Default Re: turbo traveling (Mr.DC2TurBo)
lets say full boost kicks in at 3500rpm right, when you are the highway and in 5th gear at 3500rpm with holding the gas pedal lightly(not pressed down all the way). Would you be boosting? Or boost will only kick in when you have the gas pedal to the floor? I am still confuse about that, can someone explain it to me. thanks
Old Nov 22, 2004 | 07:59 PM
B18 CYA's Avatar
Boost will only kick in when it is mashed to the floor and when it is on the pedal quite a bit. On my gsr I can cruise at even 5000 rpm's without being in boost...
Old Nov 22, 2004 | 08:03 PM
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">Boost will only kick in when it is mashed to the floor and when it is on the pedal quite a bit. On my gsr I can cruise at even 5000 rpm's without being in boost...</TD></TR></TABLE>
damn, 5k? How fast are u going with a gsr tranny to get 5K? I know for my LS 3K rpm is at 80 miles/hr.
Old Nov 22, 2004 | 08:07 PM
B18 CYA's Avatar
i was just using that as an example....
Old Nov 22, 2004 | 08:29 PM
LoSt is BlaCk's Avatar
just stay out of boost...
Old Nov 23, 2004 | 12:13 AM
illi Adik's Avatar
Default Re: (LoStMyBoOsT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOsT &raquo;</TD></TR><TR><TD CLASS="quote">just stay out of boost...</TD></TR></TABLE>
Clearly.
pjr710
Jan 5, 2009 11:15 PM
turbotime
Oct 6, 2005 05:54 PM
drjondurst
May 20, 2003 05:51 PM
vtec.dc2
Nov 7, 2002 10:04 PM
integraty
Oct 8, 2002 03:31 PM
