tps sensor questions
From: I told you to wait in the truck in Texas, United States
The rivets are actually screws..
The actual metric size is 5mm x .8mm pitch and is
around 15mm long as far as the threaded portion of the bolt/screw..
If you can't find that size,You might try a Japanese motorcycle shop
or Some use 10-32 machine screws..Not exactly the same but it works..
Here's another thing you'll want to know:
It would be best to replace them with allen head screws instead of regular phillips or flathead screws. If you are swapped, then more then likely you dont have a lot of room behind the TPS. So if you have to adjust your TPS, it is a lot easier to loosen the screws with a small allen wrench then with a screwdriver.
polything
23
Jul 27, 2012 08:23 AM
rasta420
17
Apr 11, 2003 02:24 PM
ArchAngel Sabastian
Apr 10, 2003 12:31 PM
