Cam gear setting?
Old Dec 28, 2001 | 06:17 PM
evo's Avatar
evo
New User
Default Cam gear setting?
How far can i go with my cam gear without valve/piston contact. (B16 TODA B's no head milled).
Thanks!
Old Dec 29, 2001 | 05:44 AM
evo's Avatar
evo
New User
Default Re: Cam gear setting? (evo)
Please reply if u have TODA B or C, i would like to know urs setting.
Old Dec 29, 2001 | 07:05 AM
non-VTEC's Avatar
i'm not 100% sure but i think a general rule for most honda's is +/- 4deg
Old Dec 29, 2001 | 11:07 AM
evo's Avatar
evo
New User
Default Re: Cam gear setting? (non-VTEC)
Hi, what cam have u got now?
Old Dec 29, 2001 | 07:40 PM
John's Avatar
New User
well, on some you can push farther... i did produce a tad bit more high end power w/ a -7 degrees... but i lost WAY too much low end, a even some mid... but the motor should withstand it, but i don't recommend it... but i'm sure it differs for each motor, especially if you have a SOHC or DOHC...
Old Dec 30, 2001 | 06:39 AM
evo's Avatar
evo
New User
Default Re: Cam gear setting? (DunReit)
I've DOHC B16, is 3-5 degree on safe side and balance power and torque?
Old Dec 30, 2001 | 05:51 PM
JDMek9's Avatar
New User
you should be safe with setting them at +10-10 even a little bit more should be fine. I have my SOHC type r motor with these cams set at +12 - 5 and believe me , this **** hauls *****.
Old Dec 30, 2001 | 09:57 PM
Vtec integra's Avatar
i have toda b's in a b18c1 and 12:5:1 compression pistons
i have my settings at intake:0 exhaust:+1 or -1 i forgot
its too cold to go out there and look
i'll look later
Old Jan 1, 2002 | 08:50 PM
3rdGteg's Avatar
Default Re: Cam gear setting? (Vtec integra)
Anybody knows if "each" of the markings on the old "JG engine dynamic" cam gears go by increments of 1 degree or 2 degrees? Does each line stand for +/- 1 degree or +/- 2 degree at a time?
Thanx.
(Sorry to post a question w/in a quest.)
Old Jan 1, 2002 | 09:30 PM
CRX_VTEC's Avatar
Default Re: Cam gear setting? (JDMek9)
Hmm... whats a SOHC type R motor? Typo?
Edw-R
Sep 28, 2004 12:17 PM
bulori
Dec 27, 2003 06:33 PM
pierrot le fou
Nov 27, 2003 08:52 AM
jdm civic 2000
Dec 25, 2002 09:02 AM
Maxi
Nov 9, 2001 10:37 AM
