thinking of converting to boost
Old Nov 22, 2004 | 05:07 PM
NorthernXposure's Avatar
Default thinking of converting to boost
currently my block is a b18c sleeved w/ 84mm endyn rollerwaves w/ 12.5 comp and am using crower econo rods.... aside from the obvious things to switchover and prep for boost.... could i go with a different set of rings to bring the compressioin down and still use the same pistons???? i will definitly be upgrading the rods as well.... thnx for any info fellas
Old Nov 22, 2004 | 05:32 PM
drdisco69's Avatar
Default Re: thinking of converting to boost (NorthernXposure)
You cannot raise or lower compression with rings. You need new pistons.
Old Nov 22, 2004 | 07:36 PM
mmuller's Avatar
Mad Scientist
Default Re: thinking of converting to boost (drdisco69)
yeah you need pistons
SIBlue00
Aug 21, 2007 06:46 PM
aboobybobpleez
Jan 31, 2007 01:34 AM
Flexin5
Aug 10, 2006 03:59 AM
red_si_racer2002
Aug 5, 2005 05:22 PM
