Map sensor question
Old Nov 22, 2004 | 03:27 PM
maxspeedhonda's Avatar
Default Map sensor question
I have a home-made sheet metal intake on my motor with a 68mm str TB. The placement on the str TB for the MAP sensor is threaded and I did not get the piece that threads into it. So obviously I could not put my 3 bar into a threaded hole, so I teed it off my fuel pressure regulator. I have searched and seen several members on here do the same. Will I run into any issues with the MAP like this? I am currently having some issues getting the car to idle correctley. If I don’t feed it gas constantly it will stall. Does anyone think that the MAP could be causing this?
Old Nov 22, 2004 | 06:11 PM
Default Re: Map sensor question (maxspeedhonda)
bump
Old Nov 23, 2004 | 05:13 AM
ttt for some info
boostedcivicsir
Oct 26, 2008 02:14 PM
ekk41
Oct 24, 2007 05:28 PM
ekk41
Oct 24, 2007 05:16 AM
powerdbygarrett
Oct 2, 2007 08:28 AM
maxspeedhonda
Nov 25, 2004 09:31 AM
