DIY lower control arm bushing removal?
Old Nov 22, 2004 | 01:06 PM
RTW DC2R's Avatar
Default DIY lower control arm bushing removal?
Without the use of a press, is there a way to remove old bushing and install new ones without using a press? Is there a way to do it with a vice or something? Im just trying to avoid the labor charge for this since I had it done before and was surprised and pissed when I found out how much it cost.
Old Nov 22, 2004 | 01:08 PM
GPNY's Avatar
Default Re: DIY lower control arm bushing removal? (RTW DC2)
burn em out
Old Nov 22, 2004 | 01:10 PM
AssPenny's Avatar
Default Re: DIY lower control arm bushing removal? (GPNY)
Big ******* hammer and some pipes and sockets maybe?
Old Nov 22, 2004 | 01:11 PM
Dan GSR's Avatar
<--- has a 20 ton press
you can use if you'd like
Old Nov 22, 2004 | 01:12 PM
KayOs's Avatar
A good torch would definitely be beneficial. Just take the precautions of avoiding the toxic fumes from the burning rubber......
Old Nov 22, 2004 | 01:17 PM
RTW DC2R's Avatar
Default Re: DIY lower control arm bushing removal? (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Big ******* hammer and some pipes and sockets maybe?</TD></TR></TABLE>
this is what I was thinking about trying...assuming i could find a socket or something to fit properly
dan thanks for the offer but ill just pay the labor charges rather than deal with NYC/LI traffic
Old Nov 22, 2004 | 01:39 PM
danielm3's Avatar
sounds like a lot of work
Old Nov 23, 2004 | 08:44 PM
stumpyf4's Avatar
Default Re: DIY lower control arm bushing removal? (danielm3)
Follow the instruction on Team Integra... use the Energy Suspension replacement stuff and you won't have to press a new bushing in.
Linky:
http://www.team-integra.net/se...=1025
I'm gonna attempt to start installing my energy master kit this way.
Old Nov 23, 2004 | 09:12 PM
Dan GSR's Avatar
Default Re: DIY lower control arm bushing removal? (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Follow the instruction on Team Integra... use the Energy Suspension replacement stuff and you won't have to press a new bushing in.
Linky:
I'm gonna attempt to start installing my energy master kit this way.</TD></TR></TABLE>
thats a lot of work
its a lot easier to just press them out
only takes 1min per bushing
Old Nov 27, 2004 | 01:21 PM
stumpyf4's Avatar
Default Re: DIY lower control arm bushing removal? (Dan GSR)
Agreed it a bit of work but if both the shock bushing bolt and the outer control arm bolt are seized (like on my car) and you can't remove the control arm from the car this is an easy way for someone to do it in their suspension install in the driveway.
Old Jun 14, 2007 | 02:41 PM
Kyo Babic's Avatar
bump up...
ok so i got my bushing out...and have my new oem replacement...how can i put it back in..im assuming it shouldnt just slide in..does it need to be pressed in?...is there a tool i can rent to press it back in, with out taking the arm off the car, i dont want to risk breaking another bolt PITA!
edit***never mind, that was easy, haha...i went down to canadian tire and rented a upper control arm bushing remover....for a demostic car or light truck, lol apparently it works on a LCA bushing on a honda too.
Modified by Kyo Babic at 6:07 PM 6/14/2007
.dave
Suspension & Brakes
66
Oct 25, 2019 10:50 PM
wlee112
28
Jun 25, 2007 08:08 PM
eskimo_usd
Jun 6, 2006 04:25 PM
mda27
Mar 3, 2004 07:53 AM
b20ek
Jun 2, 2003 05:06 PM
