fuse problem someone help please
Old Nov 22, 2004 | 08:19 AM
zccrx's Avatar
Default fuse problem someone help please
i keep blowing out fuse number 1 which is turn signals and somthing else and also the hazard fuse which is in the motor bay in the little black box. could it be a bad ground or maybe a starter or battery surge any one help please.
Old Nov 22, 2004 | 08:27 AM
crx_88_si's Avatar
a short to ground. somewhere a wire is touching bare metal.
Old Nov 22, 2004 | 08:32 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: fuse problem someone help please (zccrx)
Also look for water inside your turn signals..
Especially if the lenses are cracked..
Old Nov 24, 2004 | 08:33 AM
zccrx's Avatar
Default Re: fuse problem someone help please (88DXCRX)
ok i chekked all of the above still nothing i keep blowing fuses could it be the switch and does any one have one out there that i could buy. turn signal switch that is .
Old Nov 24, 2004 | 09:15 AM
88DXCRX's Avatar
Does the fuse blow as soon as you replace it or does it
usually take a while?
If so when does it blow?
{ie:When you turn on the blinker etc...}
I have seen the hazard/turn signal relay "stick" and cause the fuse to blow..
Old Nov 24, 2004 | 09:35 AM
Steadfast's Avatar
I would change every bulb just because there cheap, change the switch,(relay), and re-check ALL wiring....
EvoEK9
Jan 26, 2008 10:15 AM
jdm206
11
Sep 17, 2007 11:59 AM
vnguyen850
Mar 4, 2007 07:53 AM
ShrimpPoppa
Nov 13, 2005 11:17 AM
ModlesSI
Feb 22, 2003 03:16 PM
