MINI ME
Old Nov 21, 2004 | 06:27 PM
89 pos's Avatar
Default MINI ME
OK what head is better for a mini me on the stock cx the y8 or z6
BauleyCivic's Avatar
Risky Business
Default Re: MINI ME (89 pos)
Yes
Old Nov 21, 2004 | 06:30 PM
civictildeath's Avatar
Default Re: MINI ME (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Yes</TD></TR></TABLE>
very vague i think he means search but the y8 has higher compression ratio
Old Nov 21, 2004 | 06:31 PM
89 pos's Avatar
??????????????????????????????????that dont answer ****
InsertRacialSlur's Avatar
* B A N N E D *
Read:
https://honda-tech.com/zerothread?id=554053
I believe the Z6 is prefered since it has more flow? (please correct me if I'm wrong)
Edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">
very vague i think he means search but the y8 has higher compression ratio</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos &raquo;</TD></TR><TR><TD CLASS="quote">??????????????????????????????????th at dont answer ****</TD></TR></TABLE>
BAN! That answers a lot, you idiot-***, ungrateful ************.
Old Nov 21, 2004 | 06:33 PM
Risky Business
Y8 has higher compression, Z6 has better flow. Its a tossup.
What will make more power? Probably a Y8.
Old Nov 21, 2004 | 06:36 PM
Risky Business
Default Re: (TypeRWanter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRWanter &raquo;</TD></TR><TR><TD CLASS="quote">That answers a lot, you idiot-***, ungrateful ************.</TD></TR></TABLE>
I think he was referring to my response. I think he hates me.
Old Nov 21, 2004 | 06:38 PM
89 pos's Avatar
Default Re: (BauleyCivic)
;Y8 has higher compression, Z6 has better flow. Its a tossup.
What will make more power? Probably a Y8.; that what i wanted to know
* B A N N E D *
I think he was referring to my response. I think he hates me.</TD></TR></TABLE>
Maybe.
I think it was warranted, especially after reading your rant post .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Y8 has higher compression, Z6 has better flow. Its a tossup.
Edit: You asked what was better - that's all subjective. Some people think more flow is better, and some people think higher compression is better. You didn't ask what makes more power, now did you?
Old Nov 21, 2004 | 06:39 PM
Risky Business
I think it was warranted, especially after reading your rant post .</TD></TR></TABLE>
Oh well...what can ya do right?
Old Nov 21, 2004 | 06:42 PM
i was bein a smartass as usual and yes i was pretty pissed at bauley but i got over it and take what he says when he is being a smartass as just that
Old Nov 21, 2004 | 06:45 PM
89 pos's Avatar
Default Re: (civictildeath)
if i use the p28 do i have to have a knock sensor
Old Nov 21, 2004 | 06:51 PM
D21X's Avatar
Default Re: (89 pos)
if u have the 8 vavle cx motor, u're going to need a different block, one that had 16 valve head.
Old Nov 21, 2004 | 06:53 PM
Default Re: (D21X)
couldnt he just upgrade pistons??
Old Nov 21, 2004 | 06:54 PM
89 pos's Avatar
Default Re: (D21X)
so i am better off using the whole d16y8 motor
Old Nov 21, 2004 | 06:55 PM
probably cheaper want the whole swap
Old Nov 21, 2004 | 06:56 PM
89 pos's Avatar
witch is the best trans for that swap
Old Nov 21, 2004 | 06:58 PM
i believe the d16y7?? transmission has longer gears than the y8 trans
DAguyLS's Avatar
z6, nice short gears
Old Nov 21, 2004 | 06:59 PM
* B A N N E D *
Couldn't he just slap on the Z6 tranny to the Y7 motor?
DAguyLS's Avatar
it's D-series, right??....yup
Old Nov 21, 2004 | 07:00 PM
yes but he wants the y8 and it will still bolt on sorry about the avatar slamd
Old Nov 21, 2004 | 07:03 PM
* B A N N E D *
Default Re: (slamdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdcivic &raquo;</TD></TR><TR><TD CLASS="quote">it's D-series, right??....yup</TD></TR></TABLE>
. It was a suggestion, not a question.
Eaglekper0046
11
Dec 12, 2005 10:19 PM
mp5o
Dec 7, 2005 05:12 AM
FaceTuned
Jun 14, 2005 09:21 PM
NonovUrbizniz
May 31, 2005 12:28 PM
struppi
May 27, 2004 09:14 AM
