turbo carb engine
if i put a 1987 d15a2 carbureted crx engine in a 97 civic what would need changed out as far as fuel pump, ecu (if one) fuel lines, and other things i may need to change??
Wow, that would be different. The carb will more than likely leak, so I guess you'll have to get special seals and the carb body machined to accept them. I know little about honda's so im not going to lend advice on the rest. If you want to be that radical, how bout a draw through setup with say, a 40dcoe? Expect more people to tell you to not bother than give advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">thanks i just figured it would be cheaper to turbo and build since it needs no ecu upgrades</TD></TR></TABLE>
Chipping an ECU costs 50 bucks. Dont let that discourage you. Getting a carbeurated turbo car to run well will be a hell of alot harder than chipping an ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Chipping an ECU costs 50 bucks. Dont let that discourage you.</TD></TR></TABLE>
damn i thought it was way more than that. think il jst turbo my engine in there now. thanks a lot
