wiring gsr into eg
Old Nov 21, 2004 | 04:34 PM
NitrousB.I.G.'s Avatar
Default wiring gsr into eg
Does the yellow black wire of the IAB go to pos switched 12v source or to ground.
Modified by NitrousB.I.G. at 5:55 AM 11/23/2004
Old Nov 22, 2004 | 09:15 AM
eh2+b18c1=usdm sleeper's Avatar
Default Re: wiring gsr into eg (NitrousB.I.G.)
depends on obd1 or odb2.. if its a obd1 motor using a obd1 ecu, you can switch pins..hhmm cant remember which one, this one is widley preached so go search. if its a obd2 motor using obd1 ecu you can splice into the IAB solenoid and run it straight to the ecu to one of the injector pins. it works. so dont knock it til you try it.
Old Nov 22, 2004 | 11:29 AM
Turbogixxer's Avatar
Default Re: wiring gsr into eg (eh2+b18c1=usdm sleeper)
Run the wire to this connector (the one with the red dot) and tap into one of the wires:
That is 12v igntion power. Then run the other to A17 (OBD1)
tony7626
Nov 2, 2009 06:36 AM
laziebun
Dec 27, 2008 07:19 PM
jdmEF8racer
Oct 18, 2006 08:56 PM
Project92Hatch
May 9, 2003 03:11 PM
ozzyman
Sep 4, 2002 07:57 PM
