V-AFC Problem
i have a v-afc II and i hooked it up in my friends 00 civic si with none of the settings changed and it throws a fuel air metering code every now and then in 4th and 5th gear
please HELP any info wanted
Go back and check your wiring..
It's obviously something you did.
Also you may want to intialize the VAFC.
Make sure your You have it set on 6 in and 6 out and four cylinder and throttle pointing to the top right.
Oh btw- sorry for splleing
well make sure
the brown one is closer to the ecu than the black one
usally wen i did a vafc i would throw a code for the vtec pressure, i just assumed it was cause of cutting n splicing the wires so tahts why it thru the code. but thats the only code i ever got
