Removing copper O-ring on sleeved block
Old Nov 21, 2004 | 03:00 PM
shermanyang's Avatar
Default Removing copper O-ring on sleeved block
okay, what tools are needed to make the job easier? what methods? feedback from anyone who has attempted or have done this will be greatly appreciated!
doing this right now and about to give up...till tomorrow
Old Dec 1, 2004 | 08:44 AM
X-Mazda 3 Racer's Avatar
Default Re: Removing copper O-ring on sleeved block (shermanyang)
Here is the easiest way:
Get a used drill bit about 1/4 or larger ( must be a drill bit because the metal is hard enough and won't fold over or bend! )
Grind the bit until it has a flat wedge on it a little thinner than the o-ring groove.( like a mini chisel )
Lightly tap it into the wire ( be sure not to miss and hit the sleeve )
This should cut the wire and allow you to lift the wire out with ease.
I can get you pics of the tool I made if you need them. Hope this helps!
Vince Tiaga
Modified by GoldenEagleMfg.com at 11:08 AM 12/1/2004
RPMTOY
Jan 28, 2009 06:59 PM
mstolars
Dec 29, 2005 11:50 AM
Integralove00
Oct 26, 2004 09:40 PM
gritsak
Aug 19, 2003 12:00 AM
reaction360
Aug 17, 2003 02:36 AM
