What is this???
Old Nov 21, 2004 | 01:34 PM
D21X's Avatar
Default What is this???
What is the sensor to the left of the oil pressure switch???
Old Nov 21, 2004 | 01:36 PM
Chronic_SMOKE's Avatar
i think its a knock sensor
Old Nov 21, 2004 | 01:37 PM
]{iwi's Avatar
Default Re: What is this??? (D21X)
fan switch
Old Nov 21, 2004 | 01:38 PM
Bee17hatch's Avatar
Default Re: What is this??? (]{iwi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ]{iwi &raquo;</TD></TR><TR><TD CLASS="quote">fan switch</TD></TR></TABLE>
Old Nov 21, 2004 | 01:51 PM
BiTurboCiv's Avatar
Default Re: What is this??? (Bee17hatch)
its a coolant sensor. the knock sensor is higher and more right........ 4th gen never had a knock sensor anyways..
D21X's Avatar
Does the 92-95 civic's have this in their blocks? I have a SOHC ZC with d16z6 head going into my 92 civic hatch and im not sure if i have a harness for it or not.
Old Nov 21, 2004 | 01:55 PM
Trial User's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X &raquo;</TD></TR><TR><TD CLASS="quote">Does the 92-95 civic's have this in their blocks? I have a SOHC ZC with d16z6 head going into my 92 civic hatch and im not sure if i have a harness for it or not.</TD></TR></TABLE>
No, they have them in the thermostat housing. You can re-route the wires if you need to.
Old Nov 21, 2004 | 01:59 PM
D21X's Avatar
Default Re: What is this??? (Trial User)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trial User &raquo;</TD></TR><TR><TD CLASS="quote">
No, they have them in the thermostat housing. You can re-route the wires if you need to.</TD></TR></TABLE>
So i dont need to worry about block's fan switch, because with my vtec head, it is already on the thermostat housing correct??
Old Nov 21, 2004 | 02:46 PM
BadWay's Avatar
the t-stat housing is connected to the block. you will still use the one on the block if you are only changing the head
Yuta
Nov 5, 2015 12:16 PM
sleepingciv
Nov 2, 2008 08:14 PM
orioncivic
Sep 3, 2008 07:50 PM
endlessdv
Jan 20, 2005 09:50 PM
Jeff1119
May 24, 2004 11:39 AM
