connector wire questions
Old Nov 21, 2004 | 12:52 PM
GOTNOS's Avatar
Default connector wire questions
what color are the wires for the egr and tps connector and what order are they in?
Old Nov 21, 2004 | 02:32 PM
GOTNOS's Avatar
Default Re: connector wire questions (GOTNOS)
anyone? just go look at your car and tell me the colors hehe.
Old Nov 21, 2004 | 02:41 PM
LudeyKrus's Avatar
PM'd.
I'll check when I get home!
Old Nov 21, 2004 | 04:33 PM
GOTNOS's Avatar
Default Re: (LudeyKrus)
i recently had issues with my idle surging i checked the FICV and tightend it up then started the car and the idle was fixed went to check under the hood found out that the IACV was unpluged pluged it back in and the idle went ruff again. Read some topics and diys on both systems . Thought back to when i got the motor both FICV and IACV where off my motor was semi disassembled when i got it and i put it back together. Now im reading that the FICV and IACV both have gaskets i didnt remeber putting 1 on each of them so they said this could cause a huge vacuume leak. So i sprayed carb cleaner on the IACV and the carb cleaner was sucked right in so i think ill order some gaskets in the morning hope this solves my issue.
Old Nov 21, 2004 | 04:37 PM
H22A EG6's Avatar
Default Re: (GOTNOS)
sucked right in or evaporated?
in car cleaner it is mostly a sovent called toulene and it evaps very fast especally if there is air blowing over it
Old Nov 21, 2004 | 04:44 PM
GOTNOS's Avatar
Default Re: (H22A EG6)
sucked in.
Old Nov 21, 2004 | 05:40 PM
GOTNOS's Avatar
nvm it didnt it just evaporated would a bad o2 cause the car to idle like this? or should i try and do this http://www.92lude.com/idle_air...d.htm and see if it works.
Old Nov 22, 2004 | 03:54 AM
jackstands's Avatar
I would not trust that site, some of their "mods" are stupid . . . advancing ignition without a light? or disconnecting your fuel pressure regulator to run bring up psi.
Unsafe, unsafe, un-sage.
Old Nov 22, 2004 | 08:03 AM
GOTNOS's Avatar
Default Re: (jackstands)
ok i wont bust still what are the color combos on each connector the egr and the tps.
Old Nov 22, 2004 | 11:17 AM
GOTNOS's Avatar
can someone please go outside to their car and check the tps connector and the egr connector for me please i am curiouse on what the color combos are for each 1 (the wires). Thanks
Old Nov 22, 2004 | 02:52 PM
GOTNOS's Avatar
night bump
Old Nov 25, 2004 | 02:07 PM
GOTNOS's Avatar
bump someone help me pls.
jaap_15
Jan 10, 2012 09:42 AM
track_assassin
Jan 22, 2008 10:51 AM
Castor
Nov 14, 2004 12:32 PM
maxxd97
Nov 6, 2003 07:10 PM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
