Idle issue...
Idle issue...
hey guys. my d16z6 is having some pretty rediculous idle issues. It will idle as low as 400-500 and its nearly stalling out. Interesting things: pushing the brake pedal all the way in and releasing it often will make the idle raise up after pulling away.. And also when I slightly rev it when not in gear(like up to 2000) and immediately release the throttle completely, it will almost stall out then come back to hold idle again. It's reaaaally weird.
Any thoughts?
Any thoughts?
Re: Idle issue... (Chris M)
make sure all of you plugs and wire are working or are not fouled out.
you can take one wire off at time then replace it and if you hear a change in rmp then it's not that wire. That save a little time
Re: Idle issue... (92 CIVIC HATCH VX)
No CELs.. Doesnt appear to be the wires (brand new ngk iridiums/brand new wires)
Could be the dizzy i suppose.. but I'm not sure. The fact that the idle is affect by me pressing the break is a little weird..
ArchAngel Sabastian
09-11-2002 09:29 PM
