Quick question about ECU's
Old Nov 20, 2004 | 06:46 PM
zeleftikam's Avatar
Default Quick question about ECU's
I've got a '91 Integra, I'm putting a B16A in it (cable trans), I have an ECU that is for the B16, but it is for an automatic transmission, will it at least operate the engine semi-decently with a manual transmission installed?
Thanks,
zeleftikam
Old Nov 20, 2004 | 08:15 PM
Cjsls's Avatar
Default Re: Quick question about ECU's (zeleftikam)
yes. it may idle a little high and it will hve a lower rev limit. at least those were the symptons i had when i used an auto ecu.
Old Nov 21, 2004 | 10:13 AM
zeleftikam's Avatar
Default Re: Quick question about ECU's (Cjsls)
cool thanks.
Old Nov 21, 2004 | 10:23 AM
virusiidx's Avatar
yeah im still running my auto ecu ever since i did the auto to manual conversion, runs fine, but the CEL comes on.
Old Nov 21, 2004 | 10:48 AM
MR-MUGEN's Avatar
Default Re: (virusiidx)
just get the ecu chipped and you wont throw a check engine light and the ca will idle fine
Old Nov 21, 2004 | 11:26 AM
crawdad689's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeleftikam &raquo;</TD></TR><TR><TD CLASS="quote">I have an ECU that is for the B16, but it is for an automatic </TD></TR></TABLE>
all bseries vtec engines came w/ manual transmission....i don't follow
Old Nov 21, 2004 | 11:54 AM
LSvtec03's Avatar
Default Re: Quick question about ECU's (crawdad689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawdad689 &raquo;</TD></TR><TR><TD CLASS="quote">
all bseries vtec engines came w/ manual transmission....i don't follow </TD></TR></TABLE>
maybe it's not a usdm ecu...follow?
Old Nov 21, 2004 | 12:02 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Quick question about ECU's (LSvtec03)
It will run, but it will idle high like someone said. Plus you will throw a code or two depending on the work done. On mine, (after a 5-speed conversion), I threw a 1660 code for the automatic shift solenoid.
I assume this is not a USDM ECU?
akouznet
May 24, 2009 06:50 PM
CLE
Apr 3, 2006 05:12 PM
JDM96SpecCTR
Nov 12, 2004 08:57 PM
wpgcivic
12
May 27, 2004 12:20 PM
