1.5 DPI Injectors Connectors Hookup????
Old Nov 20, 2004 | 12:45 PM
dbailey's Avatar
Default 1.5 DPI Injectors Connectors Hookup????
I need a sanity check on the correct placement of the connectors on my 1990 Civic LX 4 door dual point injectors. There is a green connector with yellow wires and a brown one. I think the green one goes on the lower injector and the brown one goes on the upper injector. If someone has that engine in their hotrod or knows which one goes where, please help. Pardon my reference to the oxymoron! A hotrod with the 1.5 DPI in it? Yeah right!!!! Thanks guys!
Old Nov 20, 2004 | 01:27 PM
dr_latino999's Avatar
Default Re: 1.5 DPI Injectors Connectors Hookup???? (dbailey)
Green is lower
Old Nov 20, 2004 | 01:49 PM
dbailey's Avatar
Default Re: 1.5 DPI Injectors Connectors Hookup???? (dr_latino999)
Thanks dude! It was running real rich with them reversed. Now for some reason the heater is not getting hot but the temp guage is rising. Just did an engine replacement and have everthing hooked back. Any ideas why the heater is not getting hot? The needle is almost half way up and the heater isn't even warm.
Old Nov 20, 2004 | 01:51 PM
Did you bleed the coolant WITH the heater on high?
Old Nov 20, 2004 | 03:50 PM
dbailey's Avatar
No I didn't. Will that cause it to not get hot? I open the bleed screw until coolant came out but the heater wasn't on.
Old Nov 20, 2004 | 03:56 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Make sure the valve is opening...
Look at the area highlighted in the pic
and push the valve toward the firewall to open..
Old Nov 20, 2004 | 04:00 PM
By not having the heat on high when you bleed the coolant you infact allow air to stay trapped in your heater core. After you have completed a bleed with the core closed, the second you opened up to the outside loop the air escaped therefor canceling out the prior bleeding process. So, for future reference, when working with coolant, turn up the heat
Old Nov 20, 2004 | 04:23 PM
dbailey's Avatar
Makes sense about the bleeding. I'll rebleed it tomorrow with the heater on wide open and see what happens. Will also check that lever and make sure it is moving. Thanks guys for your knowledge and advice. Whoever came up with this site is a genius!!!!! So helpful! Wouldn't be so without great members like you all!
JDM C.A.R
13
May 10, 2010 07:30 AM
turbo sol
Nov 13, 2008 04:47 PM
happyabortion
Sep 19, 2006 06:28 PM
boostedh22a
May 2, 2006 12:16 PM
Tinker219
Jan 27, 2003 03:11 PM
