Removing Wire from Conector
Old Nov 19, 2004 | 09:25 PM
steve0unce's Avatar
Default Removing Wire from Conector
what is the easiest way to remove a wire from a ecu connector without damaging the connector? (i am doing the 3wire iacv to 2wire) any suggestions would help i dont want to mess anything up
Old Nov 19, 2004 | 09:44 PM
STIBungy's Avatar
get a needle and run it through the pin side, not the wire side. There are barbs that hold the pins onto the plastic plugs.
Old Nov 19, 2004 | 09:48 PM
steve0unce's Avatar
those connectors are very weak...i got the lock off just a pain to get the pin off..will try needle right now btw its a 00 civic
garyc17
16
Aug 28, 2006 09:30 PM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
mr. carpenter
10
May 6, 2004 09:11 AM
Mikey3000
Jul 7, 2002 04:53 AM
