Which headgasket for rebuild?
Old Nov 19, 2004 | 06:04 PM
j-robsDA's Avatar
Default Which headgasket for rebuild?
So I got most of my parts for my rebuild. Wisco Pistons, rings, eagle rods, arp headstuds, acl bearings,, etc. But would like to know which brand (OEM, or not)headgasket to get. Or if anyone recommends a blockgaurd and which one.
This is all on an LS
Old Nov 19, 2004 | 06:21 PM
Ben Huynh's Avatar
Default Re: Which headgasket for rebuild? (j-robsDA)
Golden Eagle offers head gaskets from 81mm to 85mm. Let me know if you need one.
Old Nov 19, 2004 | 06:40 PM
j-robsDA's Avatar
Default Re: Which headgasket for rebuild? (ben@importparts.com)
I am looking for people with experience with a certain kind of HG, like cometic for instance.
Ben, thanks for shipping so quick.
Old Nov 19, 2004 | 07:16 PM
ogabudiah's Avatar
I have gone stock gasket with copper spray.
I am building an ls turbo and i plan to stick with it.
Old Nov 19, 2004 | 07:30 PM
Ben Huynh's Avatar
You're welcome!
Old Nov 19, 2004 | 08:08 PM
PrettyLude's Avatar
oem
Old Nov 19, 2004 | 08:14 PM
j-robsDA's Avatar
Default Re: (PrettyLude)
any reason not to go with cometic or a block gaurd?
Old Nov 19, 2004 | 08:33 PM
PrettyLude's Avatar
cometic is pretty good, i've never used a bg so i can't recommend any, you haven't thought about doing a resleeve job?
Old Nov 19, 2004 | 08:44 PM
jpenman50's Avatar
Is the setup going to be full LS or LS Vtech? If LS vtech I would use the cometic gasket that is designed just for that. i have one in stock at an 81.5 mm if you need it. Let me know
Old Nov 19, 2004 | 08:45 PM
IO_303's Avatar
Default Re: (j-robsDA)
the OEM head gasket is cometic isnt it?? anyway, the OEM gasket will work just fine. As for the block guard, don't use it unless you install it right. you cant just pound them in like most people do, it needs to be lower on the sleeve, and welded in. One alternative to a BG is block posting. Here is a link to help you out.
http://www.homemadeturbo.com/t....html
Old Nov 19, 2004 | 09:13 PM
Ben Huynh's Avatar
Remember some quality head studs to keep the head in place.
Old Nov 20, 2004 | 07:38 AM
j-robsDA's Avatar
Default Re: (ben@importparts.com)
got arp headstuds already. anymore opinions
Old Nov 20, 2004 | 09:03 AM
m R g S r's Avatar
Default Re: (jpenman50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 &raquo;</TD></TR><TR><TD CLASS="quote">Is the setup going to be full LS or LS Vtech? If LS vtech I would use the cometic gasket that is designed just for that. i have one in stock at an 81.5 mm if you need it. Let me know</TD></TR></TABLE>
Yup, listen to him
Old Nov 20, 2004 | 10:39 AM
j-robsDA's Avatar
Default Re: (m R g S r)
the setup is full LS, not ls-"VTECH" lol
Old Nov 20, 2004 | 05:29 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-robsDA &raquo;</TD></TR><TR><TD CLASS="quote">So I got most of my parts for my rebuild. Wisco Pistons, rings, eagle rods, arp headstuds, acl bearings,, etc. But would like to know which brand (OEM, or not)headgasket to get. Or if anyone recommends a blockgaurd and which one.
This is all on an LS</TD></TR></TABLE>
According to Stan at inlinepro, Nothing beats an OEM part. He has used OEM head gasket's and head studs up to 600+whp before. OEM would be the way to go, thats whats being use on my Built LS also
Old Nov 20, 2004 | 08:19 PM
j-robsDA's Avatar
Default Re: Which headgasket for rebuild? (JDM S1eeper)
so here is a question. I am going to bore my block .5mil over for my 81.5m pistons. I have heard a stock HG will work fine with that bore. Am I right?
Modified by j-robsDA at 10:18 AM 11/21/2004
Old Nov 21, 2004 | 07:19 AM
Si Shane's Avatar
i have heard countless times that stock hg is fine at 81.5, i think some cars came from honda with that slight overbore, even.
j-robsDA's Avatar
bump, someone help
turbo94teg
May 11, 2011 11:50 AM
ls_bitik
Jul 9, 2007 08:54 AM
civicgeek133
Feb 8, 2007 10:50 PM
SPOOLINmatt
Feb 7, 2006 07:28 PM
b18vtek
Dec 5, 2004 07:01 PM
