90 Civic 4 door Exhaust Spring Location????
Old Nov 19, 2004 | 01:40 PM
dbailey's Avatar
Default 90 Civic 4 door Exhaust Spring Location????
Guys, I'm wrapping up my first engine change and can't remember if the spring that goes on the bolt that clamps that short pipe between the engine and the catalitic converter goes on the outside of the flange or between the two flanges. Is anybody familiar with that hook up and can let me know how those springs go back on? There are two on each end of that pipe. Thanks guys.
Old Nov 19, 2004 | 01:59 PM
drdisco69's Avatar
Default Re: 90 Civic 4 door Exhaust Spring Location???? (dbailey)
Outside, not in between. It applies tension on the bolt to press the flanges together.
Old Nov 19, 2004 | 03:20 PM
dbailey's Avatar
Default Re: 90 Civic 4 door Exhaust Spring Location???? (drdisco69)
That's where I put them but the pipe is so loose that there is not a tight fit and has to leak. Haven't started it yet but as loose as it seems, I can't believe it won't leak. I've tightened the bolts as far as they'll tighten but it is still fairly loose when I pull on the pipe. The flanges are not tight up against each other when the bolts are tight. Maybe the pipe that comes down from the engine is shorter than the one that came out of the car that was on the engine that I replaced? The engine I pulled out of mine was a 1990 engine and the one I replaced it with came out of a 1991. Could that maybe be it? Thanks.
Old Nov 19, 2004 | 03:32 PM
xci_ed6's Avatar
is there a donut gasket there?
Old Nov 19, 2004 | 03:37 PM
dbailey's Avatar
Default Re: 90 Civic 4 door Exhaust Spring Location???? (krustindumm)
Yeah there's one on each end and I made sure I put them back on. There's like maybe an inch space between the flanges with the bolts tightened as far as they'll tighten.
Old Nov 19, 2004 | 04:25 PM
4drEF's Avatar
Keyboard Humorist
did you put the cat in backwards?
Old Nov 19, 2004 | 04:27 PM
drdisco69's Avatar
Default Re: 90 Civic 4 door Exhaust Spring Location???? (4drEF)
Can't really put it on backwards, the flanges are different.
It should have about 3/4" of space between the flanges, the dougnut seal does all the sealing. You can move it all around and point it all over, but it should seal.
Old Nov 20, 2004 | 03:21 AM
dbailey's Avatar
I actually never took the cat out to replace the engine. I just didn't think there was anyway there could be that much gap and it seal. Guess I'll find out when I crank it up. Thanks.
092eg6
Oct 17, 2009 10:50 PM
93civichatchinky
Sep 15, 2007 04:25 PM
GiT LaO'd
Feb 7, 2007 01:22 PM
ITB
Nov 20, 2005 07:22 PM
TRENDSETTLER
Dec 28, 2002 07:03 AM
