timing
Im gonna assume you mean ignition timing. rotate your distributor. If you search on it, there are a lot of posts about it. I forget which way is advance, which way is retard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">but where do i shine the timing light...the little hole where i can see the flywheel or...???</TD></TR></TABLE>
Yes, It's all in the Helms. Go the the electrical section and read the
table of contents,you should be able to find exact instrutions on how to do it
awww...there it is...2 pages out of 1600 can be hard to miss....thanks
it doesnt say though, do you rotate the dist to adj timing while the car is on or do u turn it off, adj, then turn it back on and check, and then turn it off and adj more if needed???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Adjust it while it's on, but make sure you jump the service connector so the ECU doesn't correct what you change.</TD></TR></TABLE>
Also make sure the car is at N O T normal operating temp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">
Why?.............................................. ..........<----best post ever!
</TD></TR></TABLE>Why?.............................................. ..........<----best post ever!
Why?.............................................. ..........<----best post ever!</TD></TR></TABLE>
Umm I dont get what ur sayin? I doesnt seem to know that much so I could see him tryin to adjust timing with it stone cold instead of at N O T.
dr_latino999
Dec 2, 2004 09:55 PM
