Boosting Limits on F23a1...
Old Nov 19, 2004 | 11:38 AM
Sam1am26's Avatar
Default Boosting Limits on F23a1...
I was wondering who has stock bottomend f23 turboed and how much boost they were running? I'm getting ready to boost on an f23 and I'm undecide on how many lbs of boost to run...
Old Nov 19, 2004 | 11:44 AM
Legendaryyaj's Avatar
Default Re: Boosting Limits on F23a1... (Sam1am26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering who has stock bottomend f23 turboed and how much boost they were running? I'm getting ready to boost on an f23 and I'm undecide on how many lbs of boost to run...</TD></TR></TABLE>
Max ive seen is 17psi but that was tuned with EMS, look up bron. Accordfreak was 14psi on f22b block, still similiar enough.
Old Nov 20, 2004 | 09:47 AM
Sam1am26's Avatar
Bump...
Old Nov 20, 2004 | 11:33 AM
jlv55's Avatar
i wanna turbo mine too!!
Old Nov 20, 2004 | 01:51 PM
DSRxRICKY's Avatar
Default Re: Boosting Limits on F23a1... (klutch44)
i did 8psi daily driver
Old Nov 20, 2004 | 03:46 PM
accord387's Avatar
what turbo are you going to use? both accordfreak and bron i believe had a t3/t4b. unsure on specs though.
Old Nov 20, 2004 | 05:28 PM
jlv55's Avatar
Default Re: (accord387)
ya i wanna do about 7-8psi with a t3/t4b.
Old Nov 26, 2004 | 07:28 AM
jmal1919's Avatar
power matters more than psi. It seems that you can make like 280whp on the stock f23, but the question is for how long? I've seen posts like X on a stock bottom end, but only time will tell how long it will last. Yes, they way the setup was maintained & driven plays big into how long it will last too, but it would still come down to time.
To get back to your question, I'm making 224 at 6-6.5psi now, so depending on the turbo u plan to run, I would figure no more than 1bar, for that dyno #, and about 9psi daily, IMO.
Old Nov 26, 2004 | 08:22 AM
type-t's Avatar
Default Re: Boosting Limits on F23a1... (jmal1919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmal1919 &raquo;</TD></TR><TR><TD CLASS="quote">
is that to the wheels or engine?...and what are you running on the 1/4 mile..im also planning to turbo but im undecided..i already had an h22a in an accord before and it felt pretty good, but is the turbo worth bolting on stock daily driver boosting under 10 pounds?
Old Nov 26, 2004 | 08:24 AM
type-t's Avatar
oh and by the way what is your setup and is your engine stock?
Old Nov 26, 2004 | 06:51 PM
jmal1919's Avatar
Default Re: Boosting Limits on F23a1... (type-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t &raquo;</TD></TR><TR><TD CLASS="quote">
is that to the wheels or engine?...and what are you running on the 1/4 mile..im also planning to turbo but im undecided..i already had an h22a in an accord before and it felt pretty good, but is the turbo worth bolting on stock daily driver boosting under 10 pounds?</TD></TR></TABLE>
not to thread jack, but that was to the wheels. See sig
setup is ur typical setup, but with a Precision GT3561 turbo and 3" exhaust.
ser13
Dec 23, 2007 10:07 AM
M7EG6
35
Sep 25, 2007 07:25 PM
trex352
Jun 6, 2007 09:04 PM
OrangeBoost
Jun 5, 2005 05:17 PM
ras
May 3, 2005 09:14 AM
