D15b1 ? ? ? ? ?
What is a D15b1? I thought the baseline engine's ( like in the STD ) were d15b2. What is the difference between the two? . . . . C/R? . . . etc?
I looked on http://www.hondaswap.com/forum...29825 and it's not listed.
70 hp instead of 92 hp from the dx.
Now, if you wanna know the engine specs.... nobody is gonna take the time to research anything on a 70 hp engine...
I have it...
Modified by fast88std at 10:29 AM 11/19/2004
I have it...
Well I don't want all the specs but what I really need is to know what my c/r would be with a D15b1 w/ d16y8 Head gasket and a d16a6 head.
Don't even try it. THe block is worthless. You can see my threads of the hole in the block
Oh wait here it is! https://honda-tech.com/zerothread?id=1050012
-Jon
Oh wait here it is! https://honda-tech.com/zerothread?id=1050012-Jon
Ahhh . . . What?
What are you say'n?
That you had a bad rod?
I don't get it . . . . Many people here have built these motors with little to NO trouble.
What are you say'n?
these motors arent that bad, there just the same as any other d15. The comp in the 1.5's is 9.6:1 opposed to the comp in the a6 which is 9.0. So u can figure you ratio out with that figure in mind. I had a b1/z6 mini me for a while. Once you swap to MPFI and get an si tranny the b1 runs just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dent Free »</TD></TR><TR><TD CLASS="quote">Well I don't want all the specs but what I really need is to know what my c/r would be with a D15b1 w/ d16y8 Head gasket and a d16a6 head.</TD></TR></TABLE>
It won't work due to the fact that the B1 pistons only have valve reliefs for an eight valve cylinder head, and as we all known the A6 head has sixteen magical valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
It won't work due to the fact that the B1 pistons only have valve reliefs for an eight valve cylinder head, and as we all known the A6 head has sixteen magical valves.</TD></TR></TABLE>
Are you sure? . . . Cause I hear conflicting info.
Every where I look it say's 16 valves , 70 hp 1.5l
The only 8 valves are d15b6 and d15b8
Modified by Dent Free at 1:59 AM 11/20/2004
Modified by Dent Free at 1:59 AM 11/20/2004</TD></TR></TABLE>
Well damn, I feel extra stupid. I have been schooled, and after digging into myself I have indeed confused the B6 and the B8 with the B1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mackenzie »</TD></TR><TR><TD CLASS="quote">i have that motor, and im waiting on a zc swap right now. right now i swapped a ex tranny on it.</TD></TR></TABLE>
I just put a Si trans on mine with the Stock D15b1 and I can spin 2nd no prob.
D15b1 with K&n cone filter with Si cast exhaust bored a little & Si Trans, Striaght Ex. and 1st TB Butterfly taken out , With 163,000 miles
Aslo Sitting idel B18c W/ P30 Piston and ITR Valvetrain. <----Need Trans
Jonmon
Aug 29, 2004 04:51 PM
