headstud torque
Old Dec 30, 2010 | 07:53 PM
slowboy90's Avatar
Default headstud torque
what are you guys torqueing your golden eagle headstuds too for 600+hp motors? im using a cometic headgasket also do you retorque? do you use arp moly lube because mine came with torco assembly lube>???
Old Dec 30, 2010 | 08:01 PM
cibao2ner's Avatar
Default Re: headstud torque
just follow the instructions that came with them...
Old Dec 30, 2010 | 08:15 PM
cloviskilla's Avatar
i dont retourque. i do mine with engine oil in three steps to 94 ftlbs.
Old Dec 30, 2010 | 09:42 PM
redboost10's Avatar
three steps to 80 lbs with oringed/step decked block
heat cycle and retorque to 80...we found they usually loosen up 3-4 lbs
Old Dec 31, 2010 | 07:59 AM
DDTECH's Avatar
5 steps to 84 ft of torque
engine oil as well.
Old Dec 31, 2010 | 09:43 AM
mike93eh2's Avatar
you should really only do head studs in two steps...a lot less accurate the more steps you do. theres no reason at all to do more than two steps.
Old Dec 31, 2010 | 09:57 AM
I.C.C.'s Avatar
I followed the instructions provided, using the provided torco lube, and no issues... We will see soon once the engine sees some man boost!
Old Dec 31, 2010 | 10:16 AM
sanman000719's Avatar
ive alwyas hear 25/50/80 heat cycle recheck
Old Dec 31, 2010 | 10:22 AM
slowboy90's Avatar
well my head lifted off the block i have an 85mm aebs block no oring so i switched to golden eagle and getting head resurfaced
Old Dec 31, 2010 | 10:23 AM
mike93eh2's Avatar
"headlift" could be from detonation as well...
Old Dec 31, 2010 | 10:37 AM
slowboy90's Avatar
well it will be retuned this year on 116 and 23 psi
96accordsir
Engine Machining & Assembly
May 9, 2019 05:53 AM
1320vickers
Aug 3, 2018 12:30 PM
horn12007
19
Sep 20, 2010 06:02 PM
ishnathan
Sep 22, 2008 09:38 AM
V8whaaa
Oct 7, 2006 09:13 AM
