Do you Really Need a Knock Sensor??
Old Nov 19, 2004 | 05:57 AM
1SickHb's Avatar
Default Do you Really Need a Knock Sensor??
I Have A 95 Civic Hb, i blew my mini-me(1.5 vtec head)<<lol.......and i just threw a d16y8, the engine has 45,*** miles...........it runs really good,i just got my own z6 computer, so ima go connect the vtec,pressure,ground blah to the ecu.........but my knock sensor was broken so i un bolted it and just left it off...............well my question is will it work if i connect the vtec- (A-4) vtec Pressure- (D-6)....Ground the Ground to the Chasis..........but wat do i do wit the knock Sensor- (D-3)??
Thanks
Old Nov 19, 2004 | 06:03 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Do you Really Need a Knock Sensor?? (1SickHb)
Unless the ECU is chipped, your going to get a CEL for the knock sensor.
Old Nov 19, 2004 | 06:06 AM
klungemonger's Avatar
Default Re: Do you Really Need a Knock Sensor?? (JDM_Ej)
If your ecu is OBD1 sohc then it isn't looking for a knock sensor signal. It doesn't matter if there is a sensor on the block, if the ecu doesn't recognize it it means nothing. You won't get a code for that.
Old Nov 19, 2004 | 06:07 AM
handa's Avatar
I didn't have my knock sensor setup for a while and it threw a code on my b16. Fixed the CEL, but didn't notice any big differences in performance. I'd get it if your ECU requires it, for safe measures.
Old Nov 19, 2004 | 06:16 AM
Default Re: Do you Really Need a Knock Sensor?? (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">I didn't have my knock sensor setup for a while and it threw a code on my b16. Fixed the CEL, but didn't notice any big differences in performance. I'd get it if your ECU requires it, for safe measures.</TD></TR></TABLE>
That's because you have a B16. All B-series VTEC had knock sensor, but the only D16 ecu that ever recongized a knock sensor is the 96-00 P2P ecu for Y8 engines. If he's running a P28 he does not need the knock sensor. If you use a chipped P28 on a B-series VTEC you don't need the sensor either.
Old Nov 19, 2004 | 06:20 AM
Slopoke's Avatar
Default Re: Do you Really Need a Knock Sensor?? (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">
If he's running a P28 he does not need the knock sensor. If you use a chipped P28 on a B-series VTEC you don't need the sensor either.</TD></TR></TABLE>
Correct.
Old Nov 19, 2004 | 04:39 PM
1SickHb's Avatar
Default Re: Do you Really Need a Knock Sensor?? (Slopoke)
Thanks!
04silvep3
Feb 3, 2009 11:27 AM
hondakrazy
Nov 14, 2008 10:42 AM
cacahead1
Jun 8, 2005 04:41 PM
clean99teg
Sep 21, 2002 05:43 PM
