ls/vtec vtec not working help
Old Nov 18, 2004 | 12:18 PM
vaporboy12's Avatar
Default ls/vtec vtec not working help
hey thanks for anyone that can help. went to the dyno today and found out vtec is not working. they told me
the wiring is good and correct
vtec solenoid clicks when 12 volts apllied
there is oil pressure goin to the head
what could the problem be? if any one can help it would be great
thanks
Old Nov 18, 2004 | 12:22 PM
RacerXI's Avatar
Default Re: ls/vtec vtec not working help (vaporboy12)
What oil pump did you use? How is it supplied...head/turbo/etc.?
Old Nov 18, 2004 | 01:00 PM
vaporboy12's Avatar
Default Re: ls/vtec vtec not working help (RacerXI)
i am usin type r oil pump
Old Nov 18, 2004 | 01:25 PM
vaporboy12's Avatar
can anyone help
Old Nov 18, 2004 | 02:20 PM
vaporboy12's Avatar
bump
Old Nov 18, 2004 | 02:48 PM
Rod.'s Avatar
Had the same thing happen to myself. I was getting oil pressure but not enough. My line going to the head and the thread were to small. After I got the GE ls/vtec kit . vtec kicked in strong and loud
Old Nov 18, 2004 | 03:03 PM
bruthaboost's Avatar
What size oil line is feeding the head?
Old Nov 18, 2004 | 07:15 PM
vaporboy12's Avatar
Default Re: ls/vtec vtec not working help (bruthaboost)
4an
Old Nov 18, 2004 | 07:36 PM
There is your problem. Your's line is to small. Up it to -6an and you'll be fine. You're not the first to have this prob pop up.
Old Nov 18, 2004 | 07:44 PM
vaporboy12's Avatar
ok i think its 4an i bought the kit from inline pro
Old Nov 18, 2004 | 07:47 PM
vaporboy12's Avatar
im still goin to pick the head apart tomarrow make sure everything is in place where it surpose to be thanks for the help though
Old Nov 18, 2004 | 11:01 PM
Rod.'s Avatar
-6an is what you need. That is the size of the GE one. Try the bigger line then you can take the head apart. Save yourself some trouble
m2theizzy
Feb 14, 2009 05:51 PM
B18c1turboedEK
Jun 6, 2007 10:07 AM
bigislandc2
Sep 2, 2006 10:37 PM
theEGkid
May 25, 2005 10:46 AM
Casper1379
May 17, 2001 10:57 AM
