problems with shifter
Old Nov 18, 2004 | 10:32 AM
jbscivichb92's Avatar
Default problems with shifter
ever since i did my swap my shifter has been realy loose. i used the right shift linkage. i can shift into gear but when i'm in gear my shifter can rock side to side like its in neutral. any sugestions?
Old Nov 18, 2004 | 10:41 AM
Default Re: problems with shifter (jbscivichb92)
help
Old Nov 18, 2004 | 10:44 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
That is normal. Change your shifter bushing.
Old Nov 18, 2004 | 10:47 AM
Default Re: problems with shifter (JDM_Ej)
my bushings are ok.
jdm123's Avatar
get osme energy transmission bushings
Old Nov 18, 2004 | 10:51 AM
Default Re: problems with shifter (jdm123)
does anyone have a pic of how the shifter and linkage is supposed to be installed.
Old Nov 18, 2004 | 11:46 AM
Z Darkside's Avatar
http://importnut.net/shifter.htm. try this, install instructions and tips.
Old Nov 18, 2004 | 01:03 PM
civicsit's Avatar
on the shifter there is a boot that holds the ball part in place. if you brake that it moves around cause it is not set like it used to be. i broke a few of them racing so i ended up having to get an b&m shifter to fix it.. i can get the part # for the shifter, but check the boot that the shifter sits in and see if you boke the plastic peaces in side it..
good luck
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
gameknb
Jun 11, 2005 07:32 AM
BAZ
Jul 29, 2003 09:29 PM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
Regular Series
Sep 14, 2002 10:41 AM
