Important question!!!
Old Nov 18, 2004 | 12:25 AM
simplypinoyy's Avatar
Default Important question!!!
I was wondering if your timing is way off would ur car not fire up ? And if it is off and ur car doesnt start would it through a CEL ? The reason y I ask is because I changed my distributor and I think that it mite of caused my timing to change when i was putting in the new distributor... I have no CEL and my fuel pump turns on ... by my car wont fire up
Modified by simplypinoyy at 1:26 PM 11/18/2004
Old Nov 18, 2004 | 12:41 AM
boosted96midorihatch's Avatar
Default Re: Important question!!! (simplypinoyy)
yup gotta fix your timing
Old Nov 18, 2004 | 04:27 AM
Default Re: Important question!!! (boosted96midorihatch)
so do i just take out the distributor and line up the marks on the cam gear the pop it back in ?
Old Nov 18, 2004 | 04:31 AM
dizzyroc88's Avatar
are you sure the spark plugs are in the right order?
Old Nov 18, 2004 | 04:41 AM
Default Re: Important question!!! (dizzyroc88)
yes i am sure that the spark plug are in order the firing order is 1-3-4-2 in clockwise... the 1 is in the bottom left, 3 is in the top left, 4 is in the top right and 2 is right under it...
Old Nov 18, 2004 | 07:29 AM
bump to the top cuz i need an answer....
Old Nov 18, 2004 | 07:39 AM
00Red_SiR's Avatar
All Motor Mentor
It's your timing alright but the easiest answer to give you for correcting it is to follow the repair manual's proceedure. There are certain steps to follow when you remove the distributor and then put it back on, to make sure everything stays lined up. If you didn't do it correctly (which sounds like the case) the best thing to do is follow the instructions from scratch and redo it.
Old Nov 18, 2004 | 09:28 AM
IVI's Avatar
IVI
yes if your timing is incorrect it would not start the car. and no it would not always throw a cel. usually to throw a cel the car would actually have to be started already.
it is most likely related to what you just changed on the car which is the distributor.
i would remove the distributor, and re-install it following a guide to make sure its properly installed and in correct timing.
i dont know if you did but what you should have done is when installing theh new distributor, made sure that it went in at the same angle and way as the old one came out. meaning if the rotor was facing the contact for plug 2, you install it in the same exact way.
catsman50
22
Jun 15, 2010 05:21 PM
Sturg
Oct 27, 2009 12:04 AM
strategy400
Aug 11, 2008 03:49 PM
freshly boosted DOHC ZC
Jul 26, 2007 01:47 PM
95 Gizzer
Feb 16, 2003 07:30 PM
