Couple clutch changing questions?
Old Nov 17, 2004 | 02:04 PM
SLATER97EX's Avatar
Default Couple clutch changing questions?
OK tomorrow me and my buddy are going to attempt to change the clutch on my EX. Is there anything in particular I should be looking out for? Anything that will surely give problems? Any idea how long the process will take for 2 people who have never done a clutch before? haha i'm nervous about it if you couldn't tell.....one more thing, is it pretty much a guarantee that the flywheel will need to be machined? Cause we won't get it off til the evening and anyplace to get it done will be closed. Should I just buy a new flywheel? Thanks in advance for any help.
Old Nov 17, 2004 | 02:08 PM
lohatch's Avatar
Default Re: Couple clutch changing questions? (SLATER97EX)
it is pretty straight forward. if you've never done it i am going to say it will take you probably 4+ hours. make sure you use your clutch alignment tool. you can probably get away without resurfacing your flywheel also. good luck.
Old Nov 17, 2004 | 02:16 PM
SLATER97EX's Avatar
4 hours doesnt sound bad. Now if I don't resurface the flywheel, is it not going to engage as smoothly as if I had? Would it be a noticeable difference? Thanks for the reply.
B_Swapped93
Apr 4, 2013 06:30 PM
rich7777
Jan 3, 2011 03:21 PM
Heinz57
12
May 26, 2003 04:34 AM
MurphDog74
Jul 24, 2002 08:31 PM
