metallic scratch/squeal from driver side of motor
94 H22a
I had the valves adjusted which quietted down the valvetrain, and had a compression and leak down test performed which turned out good, but now the metallic scratch/squeal is more promenent. It sounds as if it is coming from the water pump, tensioner area.
Just wondering if water pumps make a metallic sound when they are going out? I don't want the water pump to go out and cause the t-belt to snap and tear up my valvetrain.
Any help I would appreciate it.
(Sorry if it is in the wrong place, figured I would get a better response here, move at will.)
Thanks
Mike
Modified by staticrex at 11:01 PM 11/17/2004
Thanks
Mike
The thing is it only does it on start up, and then at different times during the drive. Like if I am beginning to slow down and have it in nuetral and then decide to go and put it in like 2nd gear when going like 5mph it makes teh same noise. I have no clue, thanks for the help.
mike
mike
PrimeElement
Sep 15, 2007 07:16 PM
mustang5.slow
Sep 6, 2007 05:30 PM
