Just got ARP studs and Nippon headgasket... need help
Old Nov 17, 2004 | 12:39 PM
JDMlyfestyle's Avatar
Default Just got ARP studs and Nippon headgasket... need help
Ok i just my order in from Prostreetonline (BTW awesome shipping and service) i ordered the Headgasket and ARP headstuds from them.
My Headgasket is the Nippon brand. is that the oem brand? and do i use copper spray on this or no?
With the ARP's i was wondering do i torqe it to 70 ft lbs or 65 ft lbs? also do i put ARP moly lube on both ends of the stud?
On my ARP studs it says
Preload (Torqe) Recommendations
a) Torqe values are based on 75% of the fasteners yeild strength. Use the manufatures torqe sequence but do not use the engine manufactures torqe specs. Torqe the nuts to 70 Ft lbs for APR moly Lube or Torqe to 85 ftlbs with 30w motor oil
B) Due to the expansion rate of aluminum. i is recommended that the torqe should be 65 ft lbs with ARP moly lube
Old Nov 17, 2004 | 01:42 PM
no one can answer my ?
Old Nov 17, 2004 | 01:50 PM
SOHC4life 96's Avatar
Default Re: (JDMlyfestyle)
As far as the gasket goes, I don't know. Someone will know though.
For the studs, I would say since since your block is aluminum you should choose B. Don't take my word for it though. That is just what I would do. After I called ARP though. The make kick *** pieces though.
Here is a free bump for you.
Old Nov 17, 2004 | 03:46 PM
lol still no one?
Old Nov 17, 2004 | 04:05 PM
MasterKwan's Avatar
Do what honda tells you to do. Honda say's clean the mating surface and bolt it together in the right order. No copper gasket spray or any of that other crap. I've read about the copper spray stuff too. Honda builds a motor that will go 200K miles without it. Why try to improve on near perfection?
I'd read both the manual AND the instructions on the studs. The torque on the studs is higher than with bolts.
black0hatch
Honda CR-V & Element
Aug 30, 2012 01:29 PM
InDub
May 5, 2007 05:21 AM
LSEGHATCH
Aug 17, 2005 07:02 AM
yellowturbo
Mar 11, 2004 10:14 AM
BoostedSi
Aug 23, 2002 10:12 PM
