Driver side power window is messed up..HELP!
Old Nov 17, 2004 | 11:12 AM
rodvang's Avatar
Default Driver side power window is messed up..HELP!
So my window goes up and down..but it also moves forward and backwards..I took off the panel to look at the railing things..and one of them is bent..is there a way to just replace the railing or do i have to get a new door..or what..help with a diy would be best..but whatever will work..thanks guys!
Old Nov 17, 2004 | 11:17 AM
SOHC4life 96's Avatar
Default Re: Driver side power window is messed up..HELP! (rodvang)
I'm pretty sure you can just replace the track, but it wont be to easy. There aren't any DIYs for this that I know of.
How is it bent? What direction does the bend go? Is it a really sharp bend or is it gradual?
Old Nov 17, 2004 | 11:21 AM
rodvang's Avatar
Default Re: Driver side power window is messed up..HELP! (DOHC4life)
its more of a gradual bend, the front roller is off the track and bent towards the outside of the car...i tried to bend it back in place but there isnt enough room to do anything...
Old Nov 17, 2004 | 11:58 AM
2lua's Avatar
there is a 10mm bolt on the bottom left conner of the door, try to losen and adjust it. that is the only bolt that holding the center channel. to replace it all you have to do is losen that bolt and peel back the glass guide channel and pull down the center channel. be careful try not to bent any rods.
Old Nov 17, 2004 | 12:02 PM
=GAME='s Avatar
i suggest replacing the rails. simple to swap out.
after you get the new rails in, get some Silicone Lube from autozone or so and spray it down the rubber edges so the window will slide easily. thats the culprit for messed up/ derailed windows.
Old Nov 17, 2004 | 12:04 PM
cappa's Avatar
Default Re: Driver side power window is messed up..HELP! ([G][A][M][E])
I couldnt see how it just bend without you wrecking your car to begin with. Try to lube up the rubber tracks (from the top of the frame all the way to the bottom) with some wd-40 or something and see if the window still does it.
Old Nov 17, 2004 | 12:05 PM
POE's Avatar
POE
Default Re: Driver side power window is messed up..HELP! (cappa)
u will probably just have to order a new window regulator, and when u get the new one put in be sure to lube it up so this doesnt happen again.
Old Nov 17, 2004 | 12:07 PM
IVI's Avatar
IVI
my dad has an old toyota corolla 1984, and those are manual windows.
i guess they didnt engineer the railings too good on that, since they were so thin, regular use broke the rail from the end.
my fix was a bunch of wire twine and a metal hanger.
Old Nov 17, 2004 | 12:14 PM
civic_speed99's Avatar
1. It isn't hard to swap out. Go to any honda garage and tell them about it, they have an article on it. *free* I have it at home, but I am at school so I can't give it to you.
2. Don't use WD-40, tried that and ended up with more problems, go with silicone spray.
Old Nov 17, 2004 | 01:15 PM
rodvang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cappa &raquo;</TD></TR><TR><TD CLASS="quote">I couldnt see how it just bend without you wrecking your car to begin with. Try to lube up the rubber tracks (from the top of the frame all the way to the bottom) with some wd-40 or something and see if the window still does it.</TD></TR></TABLE>
I just bought the car last monday and it was like that..so im just tryin to fix everything up...
anyone know where I can get a new regulator then...just at the honda dealership or what?
ENTRAPM3NT
May 23, 2013 10:54 AM
Andyxramirez
Mar 14, 2013 07:20 PM
sleepyhead87
13
Jan 1, 2010 10:48 PM
EnKidu
Oct 10, 2004 06:43 PM
crxhfpower123
Oct 22, 2002 07:20 AM
