Anyone know if 17 X 7 Rota Subzeros with +45 offset will fit a GSR?
I got a wilwood big brake kit, but I cannot mount the calipers as my wheels will touch. Wilwood recommends +42 offset or greater. The stock spec is +38 to +42
I do not think that the Subzero comes in +42, just +40 and +45. I know that offset means different things to different manufacturers, I just need to know if the +45 offset Subzeros fit
you stock offset is +45 with the acura 15x6 wheels, since you are upgrading to 17x7 wheels you typically want a +40 offset. you can get the +45 they'll just stick out a very tiny bit more than usual. either will work for your integra as long as they are 4x100!
see my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuknSI »</TD></TR><TR><TD CLASS="quote">you stock offset is +45 with the acura 15x6 wheels, since you are upgrading to 17x7 wheels you typically want a +40 offset. you can get the +45 they'll just stick out a very tiny bit more than usual. either will work for your integra as long as they are 4x100! <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emsmile.gif" BORDER="0"></TD></TR></TABLE>
-actually the +40 offset would make the wheels stick out a very tiny bit more than usual!
45 offset will be perfect. Keep in mind that the 17" Subzeros are 7-1/2" wide, not 7" wide. 45 is the correct offset.
MikeD
Jul 24, 2001 09:05 AM
