seized rotors??
Old Nov 16, 2004 | 11:20 AM
Filliam H. Muffman's Avatar
Default seized rotors??
My rotors are rusted/ seized onto the hub. the 2 screws that hold the rotor on are stuck there.
Whats the best way to get these suckers off?
Old Nov 16, 2004 | 12:07 PM
David S. Wallens's Avatar
Default Re: seized rotors?? (JUN EK9)
Try an impact wrench. One of the hammer-operated ones should do the trick. (You can get one at Sears.)
Old Nov 16, 2004 | 12:19 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: seized rotors?? (David S. Wallens)
It's an "Impact Driver" or basicaly a screw driver w/ the steel shaft sticking out the back of the handle for hitting w/ a hammer. apply a good twisting force while striking it repeatedly. It will come off.
Old Nov 16, 2004 | 12:22 PM
alotawatts's Avatar
Put some penetrating oil on first.....wait a bit.....then like David said - Impact hammer. Be sure and use a large enough phillips head bit to fit the screw. If you have never used one before ...you just want to rap it hard once or twice to break it free.
Old Nov 16, 2004 | 12:23 PM
97civicdx's Avatar
Default Re: seized rotors?? (alotawatts)
If you strip out the screws, so to Sears and get the EZouts.
Old Nov 16, 2004 | 12:27 PM
khmboostedeh2's Avatar
Default Re: seized rotors?? (97civicdx)
drill them out, if the rotor is still siezed on, then grab your biggest hammer.
Old Nov 16, 2004 | 12:35 PM
CooBlueDAB's Avatar
Default Re: seized rotors?? (Jeterkm02)
as long as it isnt covered in much flamable liquid... Try a light blowtorching... sometimes this can help loosen up some sticky or rusty metal by expanding molecules and etc.... used same method changing my rotors and even a few rusty exhaust bolts... worked like a charm..
DONT MELT IT THOUGH... just heat it up and use an impact hammer
JBirch_97Prelude
Jun 25, 2008 05:25 PM
zirac50
May 3, 2007 05:15 PM
MadCityLude
Nov 26, 2005 05:42 PM
Drag-On23
Oct 28, 2003 08:29 AM
1992milanoprelude
Jul 2, 2001 09:36 AM
