abs light staying on????????
Old Dec 27, 2001 | 06:03 AM
suzuki99's Avatar
Default abs light staying on????????
the abs light came on ...the code is #51 which says its a motor lock....i bleed the brakes and the abs motor with no results......what the hell could it be????
Old Dec 28, 2001 | 02:07 AM
Giuseppe's Avatar
Default Re: abs light staying on???????? (suzuki99)
sensor..???
Old Dec 28, 2001 | 12:33 PM
suzuki99's Avatar
it could be a sensor...i brought to the dealer today......they cant do anything cause when they plug there computer in mine it shows up as an integra....so they will not go any further.......couls ice on a sensor do this.....cause each sensor will pull up its own code....so i dont think its a sensor....
Old Dec 28, 2001 | 12:34 PM
suzuki99's Avatar
Default Re: abs light staying on???????? (Giuseppe)
Re: abs light staying on???????? (suzuki99) 9:33 PM 12/28/2001
Old Dec 28, 2001 | 12:59 PM
court's Avatar
25 Year Member
my friend had the same prob. it ended up being the magnetic sensor behid the pad/ caliper area... it needed to be cleaned
Old Dec 28, 2001 | 01:19 PM
suzuki99's Avatar
Default Re: abs light staying on???????? (court)
i washed the car sunday night and monday the light came on...i asked honda to check it...they said when they pulled it in the ice would have melted off.....thats it....
Old Dec 28, 2001 | 01:46 PM
JSpecwest's Avatar
New User
I had the same problem, it turned out to be a blown ABS fuse.
Old Dec 28, 2001 | 01:59 PM
suzuki99's Avatar
Default Re: abs light staying on???????? (JSpecwest)
the dealer said to not check the fuses.....they said if there is a blown fuse that the whole abs would just shut down.,....maybe they dont know what they r doing.....
Old Dec 28, 2001 | 07:09 PM
Drag III Integra's Avatar
how do u pull abs code?
Old Dec 28, 2001 | 07:22 PM
alexboy's Avatar
Default Re: abs light staying on???????? (Drag III Integra)
Keep th GAY B S off that **** sux any way
Old Dec 28, 2001 | 07:49 PM
suzuki99's Avatar
to pull the abs code just connect the jumper wire under the dash....
KKRIS
Aug 28, 2012 08:19 PM
wrinkly
Jun 8, 2007 07:12 AM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
