Vtec engagement problem.... already searched.
I've search and got some answers, but still have not fixed my problem. I have a 2000 ITR. The Vtec is only working at times. And when it does work, it kicks in at around 6,500-7,000 rpm. ITR's are supposed to kick in at 5700 rpm. But a lot of the time when vtec engages, it kick in and out and hesitates to redline.
I am not getting any codes or anything. The engine oil is also fine.
Anyone have any ideas? Please help.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider »</TD></TR><TR><TD CLASS="quote">what are the mods done to your car? i think that will be very helpful. </TD></TR></TABLE>
the motor's stock other then an HKS intake and a Spoon N1 muffler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell »</TD></TR><TR><TD CLASS="quote">Is your car warmed up, oil up to temp?
Perhaps your ecu is not getting a clean signal from the oil pressure sender. You could have a bad sender or bad wiring.</TD></TR></TABLE>
yes, the car is warmed.
If the sensors are bad, wouldn't it set off the check engine light?
I do know that not every sensor will trip a CEL when it goes bad. I don't know first-hand if the oil pressure sender falls into that category. There's some discussion in this thread that suggests a bad oil pressure sensor might not cause a CEL.
https://honda-tech.com/zerothread?id=945809
