going belt crazy!!!!
Old Nov 14, 2004 | 12:16 PM
GhettoR's Avatar
Default going belt crazy!!!!
Needed some new belts for a swap 97 b18c5 into 94 ls with power steering and alternator for now. First belt, alternator is too big then the next which set me on fire , was the timing belt. The motor has skunk2 cam gears, would this make the difference? The belts came from advanced auto, looking to buy OEM, hopefully it will fix the problem.
Old Nov 14, 2004 | 02:34 PM
NXSpoon's Avatar
Default Re: going belt crazy!!!! (TEGN4SHO)
Looking for OEM?? Go to the dealer and get the belts there for a Type R.
Old Nov 15, 2004 | 06:46 AM
GhettoR's Avatar
Default Re: going belt crazy!!!! (NXSpoon)
For the timing belt, would the cam gears cause the belt to be tight before tension?
Old Nov 15, 2004 | 07:20 AM
hype r 555's Avatar
Default Re: going belt crazy!!!! (ONELOVEB)
i had the same problem with my itr and found that the only t-belt that would work was the factory belt ....
Old Nov 15, 2004 | 08:11 PM
GhettoR's Avatar
Default Re: going belt crazy!!!! (lsed-eg)
thanks got one on order from prostreet.
Old Nov 15, 2004 | 08:52 PM
nfn15037's Avatar
Man why are you guys using autozone belts on ITR motors? Spend the little bit of $ and get OEM
Old Nov 17, 2004 | 08:12 AM
GhettoR's Avatar
Default Re: going belt crazy!!!! (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Man why are you guys using autozone belts on ITR motors? Spend the little bit of $ and get OEM </TD></TR></TABLE>
First time replacing the belts, didnt realize oem was that important but i know now.
vtec_01
Dec 12, 2011 05:14 PM
808DB1
Sep 7, 2008 04:34 AM
eg714
Jul 9, 2007 06:21 AM
RockstarJR
Feb 5, 2004 11:51 AM
IdahoHybridAccord
Mar 27, 2003 05:15 PM
