OBD-II ECU Modification
Old Dec 26, 2001 | 01:13 PM
Ausmith's Avatar
Default OBD-II ECU Modification
I need to have the Fuel Cut Removed or raised on a 2001 Prelude SH ECU. Any thoughts on who to turn to?
Thanks
CG
Old Dec 26, 2001 | 01:38 PM
chi1874436's Avatar
Default Re: OBD-II ECU Modification (Ausmith)
certain ignition systems will allow you to manually adjust your rev limiter.
Old Dec 27, 2001 | 06:53 AM
Anubyss's Avatar
Check out Hondata.com if you really want to raise your rev limit. Basically $150 to $300 on the ecu, $200 for the harness, $330 for the Hondata unit. You'll also need to upgrade the springs and retainers (about $400). Installation price won't be cheap either. I don't think this is worth it unless you are looking at some major increase in horsepower, and NEED the engine management.
Old Dec 27, 2001 | 10:07 AM
DirtyLude's Avatar
Default Re: (Anubyss)
You really have no options if you wish to keep the ATTS. The 5th Gen ECU cannot be chipped. No ignition modifier will allow you to raise your rev limit. If you go to Hondata or any other standalone you will lose your ATTS functionality.
Old Dec 28, 2001 | 08:25 AM
Ausmith's Avatar
Default Re: (DirtyLude)
Thanks....
We can not run a OBD-II to OBD-I conversion or any external device. Everything must remain in the stock ECU housing and nothing can be hacked into the harness. The rules of this certain class say so...
Not looking for any more power, just a few more revs before the fuel cut comes in.
No - we can not loose the ATTS.
Dirtylude - you seem to know a bit about the Lude. I do not. I know everything under the sun about the DC and EG chassis, I'm just trying to help a fellow road racer. Do you know if the JDM ECU offers a higher fuel cut?
Thanks
CG
Phet7
Oct 5, 2011 09:29 PM
BUCK_NASTY
Apr 20, 2007 08:55 PM
osuPrelude
Oct 21, 2002 07:46 AM
LOwrestling2001
Mar 4, 2002 06:45 PM
