~~climate control console~~
yea. first of all under the glove box u need to first remove the ac wire. then remove the hazzard & defogger buttons. u need to use a small flat head screw driver after that there are 2 screws taht u need to remove after that it will just pull out.
can anyone specifically describe how to remove the hazard/defog buttons to access the two screws? i removed the buttons but only the covers came off and i tried prying out the switches from the bottom and they wont come out. so frustrating....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supersonicblue »</TD></TR><TR><TD CLASS="quote">theres a slit on the bottom of each button where you can stick a flathead into.
put it in, hold the button down with your thumb and pry</TD></TR></TABLE>
i just tried that.. no luck and im startin to damage the plastic around the switch. anyone else have any ideas?
EDIT: got them out.. just had to pull hard. hehe
Modified by yangrou8 at 10:01 PM 2/26/2005
I LUV MY EJ1
Oct 21, 2008 08:37 PM
Scott in MN
Sep 26, 2007 06:25 AM
EKtypeRhaTcH
Jul 8, 2003 10:55 AM
