AXEL TO HUB problem
Old Nov 13, 2004 | 04:38 PM
InTeGrA B18b1's Avatar
Default AXEL TO HUB problem
i can get the axel in the hub whent eh lower ball is in. I dont know what to do..
Old Nov 13, 2004 | 04:44 PM
86si's Avatar
Default Re: AXEL TO HUB problem (InTeGrA B18b1)
put the axle in the hub before you install it in the ball joint
Old Nov 13, 2004 | 06:08 PM
Default Re: AXEL TO HUB problem (86si)
well the when i bolt up the lower ball joint i dont have enough room to put my axel back in.
If i put my axel in first i can't get it line it up with the lower ball joint.
Old Nov 13, 2004 | 06:59 PM
ttt
Old Nov 13, 2004 | 07:47 PM
eda6's Avatar
Install axle in the tranny or intermediate shaft. Make sure the clip locks in place. Install other end of axle into the hub. Install the knuckle into the lower control arm. Tighten nut on the ball joint and install new cotter pin.
Old Nov 13, 2004 | 10:05 PM
Default Re: AXEL TO HUB problem (eda6)
for some reason it doesnt reach. does the pin to the tranny have to clip on perfectly or it wont axel wont fit?
Old Nov 13, 2004 | 10:15 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
sounds like your axle is not seating into the transmission or intermediate shaft. use the knuckle to create a slide hammer action if this is the case. with new axles, once it clicks in, its in. the new spring has too much springiness to come out without folding most times. so get it right the first time.
Old Nov 14, 2004 | 09:50 AM
Default Re: (mike_belben@yahoo.com)
can teh axel pop out of joint? the axel is too long
boarding2008
Jul 29, 2010 05:56 PM
gcrash
Oct 4, 2009 12:56 PM
crx18c1
10
Apr 17, 2007 10:17 PM
B18CYAAA
Nov 25, 2006 01:22 PM
deviant1
Oct 23, 2003 09:10 PM
