car turns over funny.
Old Nov 13, 2004 | 09:04 AM
type Gendy's Avatar
Default crx motor in std?
So i went to buy this 91 std. The guy said it died on him while driving it. He thought it seized.
I pulled all the plugs and they were corroded white. I cleaned them up with a wire brush. Cranked the motor over by hand and it was easy. Put the plugs back in and it cranked harder. So its not seized and its got SOME compression.
Next thing: Battery is one big pile of corrosion and acid. I cleaned that all up. Went to start the car and it seemed like the battery was dead. So i throw in my battery.
Car is now turning over, but it sounds like i'm trying to start it with no plugs in it. Turns over real easy and effortless, but like it has no compression.
Where else should i look to?
Modified by Evil Sick hatcheM at 10:29 PM 11/15/2004
Old Nov 13, 2004 | 10:06 AM
dr_latino999's Avatar
Default Re: car turns over funny. (Evil Sick hatcheM)
Hmm....could one of the valves not be working right? Top of my head idea is to run a quick compression test to see if the cylinders are even holding a marginal amount of pressure.
Old Nov 15, 2004 | 05:24 PM
type Gendy's Avatar
Default Re: car turns over funny. (dr_latino999)
Doesn't look like it has ANy compression. Sounds like its got a broken timing belt.
My next Question:
Can i swap in my crx dx motor into the STD hassle free? Using crx axles and putting the std 4spd tranny onto the crx motor using crx clutch??
Old Nov 16, 2004 | 09:09 AM
type Gendy's Avatar
Old Nov 16, 2004 | 04:02 PM
type Gendy's Avatar
maybe i oughta make a new thread for second question...
Old Nov 16, 2004 | 04:07 PM
Yes you can swap over everything, hell even the CRX transmission if you want as long as you retain the stock axles from the STD. The only difference with the axles lies within the hub side, not the transmission side.
Old Nov 16, 2004 | 04:08 PM
type Gendy's Avatar
ah ****, so i'm in trouble.
STD axles are bad. I was going to use std tranny with crx dx axles = no good?
Old Nov 16, 2004 | 04:10 PM
Super Chicken's Avatar
Actually, I have a Sexually Transmitted Disease with my 88CRX Si engine and tranny in it with the one STD and one Si axle in it. They are the same
Old Nov 16, 2004 | 04:15 PM
type Gendy's Avatar
Default Re: car turns over funny. (Super Chicken)
really?????
That whats the talk of having to swap out std hubs all the time? I know thats for b series swap...but that means its differnt than dx/si hubs?
Old Nov 16, 2004 | 04:20 PM
The CRX HF and STD both had narrow end axles so therefore someone here has the wrong axle.
Old Nov 16, 2004 | 04:42 PM
I could be mistaken, but I believe it's only the HF that has the narrow axles.
Old Nov 16, 2004 | 04:47 PM
type Gendy's Avatar
nah its hf and std
Old Nov 16, 2004 | 04:51 PM
Thats funny cause my daily driver has one of each in it. I just looked it up on line at Majestic Honda and they have a different part number for every EF model SI, STD, HF DX whatever they list a different part and different price!
23 Spline versus 26 Spline. I guess my STD had a swap done while no one was looking
Old Nov 16, 2004 | 04:53 PM
type Gendy's Avatar
well if it DID have a swap done, you wouldnt be using a std axle...
how do u know u have an std AND si?
Old Nov 16, 2004 | 05:03 PM
Well the CRX SI I had owned for many years and was a bone stock Si wheels and engine and everything was original till my crackhead stepsister bought it (well it was bought for her) and wrecked it, so I found a 90 STD 1.5l 4 speed with no accesories at all and a sick engine and swapped the complete engine, tranny, wheels and wire harnesses out. I even swapped the tilt steering and intermittent wipers out! Did Honda make a stripped down model with a 4 speed 13" steelies no trunk light or rear speakers plastic seats, no console around the shifter and no hatch cover that wasn't an STD?
Old Nov 16, 2004 | 05:10 PM
HatchBox's Avatar
Skoobie no more...
si and std axles are differnet...
anyways, does the motor have fuel, spark?
if so i would go to autozone, rent a compression tester and test for compression is the cylinders and go from there.
also when you want to swap in the crx motor, get ready for dpfi-mpfi
Old Nov 16, 2004 | 05:11 PM
type Gendy's Avatar
Did u swap out the front hubs as well?
Old Nov 16, 2004 | 05:13 PM
type Gendy's Avatar
Default Re: car turns over funny. (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Sick hatcheM &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't look like it has ANy compression. Sounds like its got a broken timing belt. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
also when you want to swap in the crx motor, get ready for dpfi-mpfi </TD></TR></TABLE>
crx dx motor is dpfi ...w00t
Old Nov 16, 2004 | 05:16 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Sick hatcheM &raquo;</TD></TR><TR><TD CLASS="quote">Did u swap out the front hubs as well?</TD></TR></TABLE>
go to molts and pick up some crx hubs
is the timing off? ... im sure you could tell if the belt was broke.
and it doesnt hurt to do a compression test..
Old Nov 16, 2004 | 05:17 PM
type Gendy's Avatar
yeah i did the compression test, there was nothing
When i look in the oil filler cap at the valve/rocker and have somebody crank it over, NOTHING MOVes.
Basiclaly i'm trying to get this car on the road for as cheap and with the least amount of hours possible. I think picking up some used axles with be the easiest thing to do.
Old Nov 16, 2004 | 05:18 PM
No I didn't
Old Nov 16, 2004 | 05:21 PM
type Gendy's Avatar
So teh car musta been a dx. What motor did u swap in?
Old Nov 16, 2004 | 05:26 PM
CRX Si 1.6 D16A6
DX Civic's come with the rear wiper and center console etc. I have one of those in my driveway too.
Modified by Super Chicken at 2:37 AM 11/17/2004
Old Nov 16, 2004 | 05:34 PM
type Gendy's Avatar
i still dont get how your using an si axle on an std hub
Modified by Evil Sick hatcheM at 9:47 PM 11/16/2004
Old Nov 16, 2004 | 05:37 PM
Me neither
GI8U2racing
Sep 19, 2007 09:56 AM
jk11blueboi
Dec 7, 2006 10:05 PM
The Weather Man
Apr 7, 2006 05:09 AM
Stick2shiFTN
Oct 12, 2005 12:14 PM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
