went to the track for the first time last night....something weird happened..please help
Old Nov 11, 2004 | 09:27 PM
a1320addict's Avatar
Default went to the track for the first time last night....something weird happened..please help
alrite....im not a pro at driving or anything close
i taught myself how to drive stick 3 months ago and last night something went screwy
i was at the track and launched from about 5k. i popped the clutch out, maybe a little to fast because of the CRAZY *** wheel hop and spin...but once the traction grabbed...i shifted to 2nd...and the car just revved.....no transfer of power from the motor, then to 3rd...and the same...then about 3 seconds later i was off....any idea as to what happened? i ran the car 3 more times and eveyrhting was fine....im just very curious
Old Nov 11, 2004 | 09:33 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: went to the track for the first time last night....something weird happened..please help (yehikn
Clutch might have slipped.
I'm just curious as to why you're launching at 5k. What kind of mods have you done?
Old Nov 11, 2004 | 09:36 PM
my engine modifications are injen short ram intake, comptech 4-2-1 stainless steel headers, and hks hi power exhaust.....i actually lined up against my friends type r mabye i got a little throttle happy...any suggestions for next time im going down next wednesday
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">Clutch might have slipped.
I'm just curious as to why you're launching at 5k. What kind of mods have you done?</TD></TR></TABLE>
Yeah 5k seems a little high if your not going to slip it at all.
Old Nov 11, 2004 | 09:38 PM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah 5k seems a little high if your not going to slip it at all.</TD></TR></TABLE>
Well, I don't know how he released it... I'm thinking he dumped the clutch right at 5k causing all that wheel hop and what not. But if your car is driving fine now. I wouldn't worry. What I would do though just in case (I mean better safe than sorry) is to change your tryanny fluid. You might find metal shavings in there and you wouldn't want that recirculating back in your tryanny now.
rovigian's Avatar
so any suggestions for next weekend....it was my first time down...my best run was a 15.7....i dont need to hear any of you laugh...we all start somewhere.....can anyone give me some pinters?
Old Nov 11, 2004 | 09:42 PM
good call....totally slipped my mind.......so...still.....i need some suggestions
Old Nov 11, 2004 | 10:11 PM
rovigian's Avatar
From my experience, with FWD, if you are on anything but slicks, let it slip just a little off the line. Completely dropping it has usually caused my motor to bog hardcore, and killer wheelhop.
Plus when you completely drop the clutch it will also kill your stock motor mounts. I would recommend that you put in motor mount inserts, they are cheap (only $40 bucks) and really work. They got rid of wheel hop for me, and I can practically drop the clutch without wheelhop now.
Old Nov 11, 2004 | 10:13 PM
xprohx's Avatar
I think too much
I think the clutch might have slipped too if the car was in gear and all it did was rev.
My first time at the strip I liked to pop the clutch too, but live and learn.
Old Nov 11, 2004 | 10:44 PM
8point6's Avatar
It sounds to me that the clutch slipped. As far as launching technique goes, there is a thread around here that explains in detail how to launch on different setups.
Old Nov 11, 2004 | 10:53 PM
xprohx's Avatar
I think too much
Read this, https://honda-tech.com/zerothread?id=635736, good thread on launching and such
Old Nov 11, 2004 | 11:03 PM
Sack Master's Avatar
I don't know what these guys are talking about. I used to launch pep boy $25 tires at 4500-5k and pull 2.1 60ft times. It's a better decision to get a good clutch(ONE THAT WON'T SLIP) and learn how to peddle the throttle(incase you have a mishap) and use that clutch well. I understand you are fairly new and you will get better. Launching takes practice. Every car is different. You just need to be persistent and consistent. But as stated before get some motor mount inserts. They may make it a little bit rougher but they help out a lot.
As for what happened. I'm sure it was your clutch slipping. Get a new one. One that is best suited for your needs.
Old Nov 11, 2004 | 11:33 PM
In-N-Out Burger
Look... There's a difference between launching and knowing how to launch.
I pose'd the question why he was launching that way because he seemed like a new guy just trying to learn something and trying to start somewhere.
It is now obvious that he hasn't practiced any launching tricks that works for him and his car.
And who gives a **** if you can launch on dirty *** pep boy tires?
Continuing to be pro for launching at 5k will just induce him to keep doing the same resulting in catastrophic situations, as in destroying his clutch and tryanny.
Old Nov 12, 2004 | 07:53 AM
well thanks everyone.....first out of my 10 or so topics i havent got flamed. i really appreciate all the help...going down to the track one more time beforee the season ends...then the cars going in the garage for the winter and ims aving up for a drag 4 kit will get a new clutch flywheel motormounts and lsd.....thanks everyone....honda-tech rules
Old Nov 12, 2004 | 10:08 AM
moacsupreme's Avatar
Best advice I could give would be, give up that pointless drag racing ****.......and go road racing. A lot more satisfaction being on a track that actually has turns in it. J/k. If this is a daily driven car, and you're taking it to the strip and having problems like this. I'd say it's just going to be a matter of time before your clutch explodes, and you're without a car. Good luck to ya.
Old Nov 12, 2004 | 10:47 AM
batmang yO!
Guest
Posts: n/a
Just remember this...
some wheel spin is good, too much wheel spin is bad as it leads to tire hopping which is really bad.
poping the clutch at 5k is bad as it will obviously lead to too much wheel spin/tire hopping, unless you have slicks if you have slicks and want to launch at 5k then watch out for you cv axels, and clutch and what-not.
Old Nov 12, 2004 | 12:36 PM
jinteg730's Avatar
dont launch from 5000 enless ur ridin on good *** tires
Old Nov 12, 2004 | 12:37 PM
jinteg730's Avatar
where are you from in nj
Old Nov 12, 2004 | 04:13 PM
east orange
Old Nov 13, 2004 | 12:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">Look... There's a difference between launching and knowing how to launch.
Continuing to be pro for launching at 5k will just induce him to keep doing the same resulting in catastrophic situations, as in destroying his clutch and tryanny.</TD></TR></TABLE>
IMO it would be best to just learn how to launch properly instead of just doing whatever doesn't spin his tires too hard or doesn't bog. I know too many people that got into the bad habit of launching poorly and now they have pretty quick cars and lose the race on the holeshot. I would imagine its easier to get into good habits to begin with than trying to correct bad habits.
Old Nov 13, 2004 | 09:43 AM
Das Nuge's Avatar
I have no knowledge on how to launch my car.
So you guys are saying launching your car at 5000 is bad?
Then what is good? 3000-4000 or 6000+?
I'm so confused.
Old Nov 13, 2004 | 05:57 PM
Default Re: (B18C1_DN)
from what ive gathered from this post and searching a bit....the purpose of a launch is to get a nice hard pull off the line...and wheel spin and hop would make that harder to do. i get a nice launch at about 4k now...doing what i have searched/learned and what i have gathered from this post.....so im going down to the track again next wednesday....going to see whats up th en
one slow coupe
Jun 11, 2005 12:14 PM
Cor ey
Oct 3, 2004 09:44 PM
scrubachu
May 30, 2002 02:15 PM
strils
May 11, 2002 01:51 PM
