HELP PLEASE!!
okay here's the problem, how come everytime i start my car the clock re-set itself? Is there something wrong with the memory wire in my wiring harness? I've tried hooking up a head unit and the memory is not working so everytime i start my car every function on the head unit gets re-set and also my clock. Could it be the memory wire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 858_draGgerZ »</TD></TR><TR><TD CLASS="quote">okay here's the problem, how come everytime i start my car the clock re-set itself? Is there something wrong with the memory wire in my wiring harness? I've tried hooking up a head unit and the memory is not working so everytime i start my car every function on the head unit gets re-set and also my clock. Could it be the memory wire?
</TD></TR></TABLE>Your mem. wire is not wired to a conn. power.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 858_draGgerZ »</TD></TR><TR><TD CLASS="quote">what does that mean? a lil more info please? </TD></TR></TABLE>The memory wire, [yellow in most HU] is not wired to a 12v+ constant, you have the constant, [yellow] connected to a 12v+ that opens, [not live all the time] when you crank the motor to start OR there is a problem with the HU and a drop in voltage in causing the problem, check this, if you turn on ign. to acc., [so HU comes on] set the radio and clock, turn off the ign. wait a min. then turn it back on to acc., if it lost memory, [yellow is not wired to a 12v+ constant] memory is still there, [ you have a problem with HU or the 12v+ constant you are wired to is N/G and the voltage is droping too much] try moving the memory wire to another 12v+ constant, also check the ground wire for the HU.
94
94
Try holding the "ATT" button, let the unit power down. Cut the unit back on, set the settings. Cut your car off, then back on.. See if that fixed it. Do that before you go through the trouble of checking your wiring.
acardboardllama
Jul 11, 2013 10:28 AM
plzhitvtec
Audio / Security / Video
Aug 30, 2004 10:33 AM
