new pioneer headunit problem!
Old Nov 9, 2003 | 01:12 PM
SleepnCiViC's Avatar
Default new pioneer headunit problem!
ok guys i put my head unit in the 96 cvic ex, Now everything worked fine except, at first wehn id turn the radio off then back on it kept reseting and id loose all my bass setting etc... second i changed a some wiring now the headunit just wont shut off even after i take the key out, it seems to just continue running off the battery. Now can you guys help w/ this to it turns off and not reset all my setting when it does turn off
Old Nov 9, 2003 | 04:04 PM
Skip01's Avatar
Default Re: new pioneer headunit problem! (SleepnCiViC)
Sounds like you have a probelm with your memory wire,don't know how to fix it,sorry.I think its the yellow wire.
Old Nov 9, 2003 | 07:20 PM
B18C_EJ8's Avatar
You need to connect the yellow wire off the head unit to the wire that receives constant 12volts. You need to connect the red wire off the head unit to the wire that receives 12volts only when the key is in the acc or run position. Are you using a wiring harness? Or did you just cut the plug off and splice everything together? Need to provide more information than what you have...
Old Nov 10, 2003 | 07:11 AM
4doorex's Avatar
Okay lets see if i can remember...
Your yellow wire coming from the radio should be connected to the white with blue stripe wire on the car harness, and the red wire from your radio should be connected to the yellow with red stripe wire.
*Disclaimer*
I used to be a car stereo installer, although it's been a little while since I worked on a Honda, the information stated above is what I can remember, not fact. Use my info at your own risk, I am not responsible when your car catches on fire, you should have taken it to a professional if you didn't know what you were doing.
Matt
Jooleeus
Audio / Security / Video
Dec 23, 2009 05:30 AM
jdmthug
Mar 11, 2007 11:04 PM
fergs96integra
23
May 22, 2006 09:17 AM
eg ferio
Oct 27, 2003 04:19 PM
MisterHYBRID
Aug 28, 2003 07:47 AM
