Head Unit Problems...
Old Aug 7, 2004 | 09:19 PM
eL's Avatar
eL
Default Head Unit Problems...
Ok....
Sometimes while driving my head unit will just turn off then turn right back on. I made sure the harness was fine and everything was connected correctly. What other things should I look for? It's pretty annoying to be listening to a song and have the HU just shut off then start back up.
Any ideas? Thanks.
Old Aug 7, 2004 | 09:49 PM
john666's Avatar
Default Re: Head Unit Problems... (eL)
perhaps a loose speaker wire someplace
Old Aug 7, 2004 | 09:56 PM
eL's Avatar
eL
Default Re: Head Unit Problems... (john666)
It's the HU's power, not a speaker wire problem.
Old Aug 8, 2004 | 10:06 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">It's the HU's power, not a speaker wire problem.</TD></TR></TABLE> Does the power go off on HU, or just the sound?
If it is just the sound, a speaker or speaker wire shorting out will shut off the HUs amp.
If it is the acc. power on the HU,[ no lights, nothing but it keeps memory presets and clock] its the red acc. wire connection or in the HU.
If it also loses memory its the yellow constant power wire, or in the HU, also check the fuses, with HU on wiggle the fuses in there sockets.
hope this helps. 94
Old Aug 8, 2004 | 11:11 AM
bodiez's Avatar
Hit the floor!
Default Re: Head Unit Problems... (fcm)
Use a voltimeter and check for unstable current in the +/- wires.
Also, pull on each wire in the harness and make sure each one is secure in the harness
Old Aug 8, 2004 | 04:45 PM
eL's Avatar
eL
If its not the harness... could it be anything else?
It's the power to the HU... its not losing memory or presets or anything... so I'm not sure if its the harness.
Old Aug 8, 2004 | 05:09 PM
HiRevn's Avatar
Default Re: (eL)
Maybe there's a loose connection inside the HU.
Old Aug 8, 2004 | 06:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">If its not the harness... could it be anything else?
It's the power to the HU... its not losing memory or presets or anything... so I'm not sure if its the harness.</TD></TR></TABLE> It has to be the acc.,[red wire] pull HU out of dash check all the connections on the red wire, wiggle plug in back of HU [ with radio playing] also the adpt. plug to oem radio plug, use butt end of screwdriver and tap all over top,sides,back, and bottom of HU. 94
Old Aug 9, 2004 | 06:51 PM
hcivic99's Avatar
could be fues chech them out and if they are ok then it could be a speaker short
Old Aug 10, 2004 | 12:37 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: Head Unit Problems... (cord18s)
Sometimes, blown speakers will short the radio to turn off. Bumps in the road may cause exposed speaker terminals, such as those in the front doors, to touch the metal and cause the radio to short and momentarily turn off or cut off sound.
Old Aug 10, 2004 | 01:04 PM
teamxtant's Avatar
Default Re: Head Unit Problems... (ScareyH22A)
Shorting speaker will not cause your head unit to shut off, it will cause the IC chip inside your deck to fry, at which point you will no longer hear sound coming from your deck. From the sounds of it, you have a detachable faced unit. What happens is, when the contact between the face and deck get corroded, the contact is lose momentarily. This cause the deck to think you have just detached the face and turns your deck off. Clean the contacts behind the face of your unit with a pencil eraser. It should fix the problem.
Old Aug 10, 2004 | 11:54 PM
IVI's Avatar
IVI
Default Re: Head Unit Problems... (teamxtant)
i had the same problem
the custom constant +12v i ran to the fuse box was a bit loose.
make sure your wires are not loose.
Old Aug 11, 2004 | 06:52 AM
fcm's Avatar
fcm
Old Fart
Default Re: Head Unit Problems... (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem
</TD></TR></TABLE> Not the same problem, he does not lose preset memory or clock, as you would if yellow ,[ constant ] got disconnected. 94
Old Aug 11, 2004 | 01:22 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Not the same problem, he does not lose preset memory or clock, as you would if yellow ,[ constant ] got disconnected. 94</TD></TR></TABLE>
sometimes it would make my headunit just shut off and then turn right back on automatically
sometimes it would reset everything
it was usually everytime i hit the clutch because my clutch foot would snag the wire at the tip and move it.
Old Aug 11, 2004 | 06:44 PM
fcm's Avatar
fcm
Old Fart
</TD></TR></TABLE> Like I said not the same problem, your problem is just a getto install lol 94
nate_o
Audio / Security / Video
Jul 16, 2013 10:13 AM
92ehatch
Nov 16, 2005 03:14 PM
alien6067
Feb 16, 2005 05:38 PM
bigfatchien
Oct 25, 2004 10:44 AM
NonAutoX
Nov 27, 2003 02:20 PM
