Code 21 Problems
Old Nov 11, 2004 | 04:18 PM
quik1's Avatar
Default Code 21 Problems
I just put a B16 in a 93 civic DX everything seems fine except I'm getting a code 21 (vtec solenoid). I've already swapped ecus with a know good one. I checked for continuity from pin A4 to the solenoid, its all good. I've done about 10 of these swaps before so i'm pretty confident in the wiring. What do you think new solenoid? BTW I have done a search already didn't tell me much.
Old Nov 11, 2004 | 07:01 PM
eda6's Avatar
Default Re: Code 21 Problems (quik1)
Did you ground the black wire?
Old Nov 13, 2004 | 08:13 AM
quik1's Avatar
Default Re: Code 21 Problems (eda6)
Do you mean the black wire on the pressure sensor? If so than ya that is grounded.The problem is in the solenoid though.
Old Nov 13, 2004 | 08:20 AM
mmuller's Avatar
Mad Scientist
have you tried talking out the sol. and cleaning it?
Old Nov 13, 2004 | 09:15 AM
b18cx's Avatar
Default Re: Code 21 Problems (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">have you tried talking out the sol. and cleaning it?</TD></TR></TABLE>
and make sure the filter screen is clean too
Old Nov 13, 2004 | 12:31 PM
quik1's Avatar
Default Re: Code 21 Problems (b18cx)
Would that make a code pop up as soon as I turned the car on?
Old Nov 15, 2004 | 07:34 PM
quik1's Avatar
Thought I'd let people know what it was so that you don't search through posts that lead no where like I did. It tuned out that the pin I was using wasn't making contact with the ecu(bad pin).The way I found out was I checked for continuity from the ecu harness to the solenoid, it had continuity( so automatically you think everything is good from the ecu to solenoid, wrong). I then removed the cover of the ecu and checked from the inside of the ecu to the solenoid, no continuity even if wiggled the pin around. I tried another pin in there a problem fixed.
Thought I'd throw my 2 cents in, I hope it helps someone some day.
Old Nov 15, 2004 | 07:49 PM
eda6's Avatar
I hate electrical gremblins. Glad you figured it out
lvlistchif
Sep 25, 2009 02:43 PM
B16tyler422
Jun 16, 2007 05:04 PM
88 rex
Aug 31, 2006 08:24 PM
ken-e
Dec 20, 2005 10:03 AM
Hondasaurs
May 5, 2003 03:00 PM
