CEL code came on today... =(
so the code came on today and i went to autozone to get it checked. the code says something with the ignition is wrong. changed the spark plugs and wires, reset the code. a few minutes later it came back on. is there a way i can narrow it down to what exactly is wrong with the ignition? what else could it be?
have you trried jumpin the ecu to find out the code for yourself and checking the thread about cel codes? thats helpful. just a FYI.
https://honda-tech.com/zerothread?id=978933
yeah, i also checked that, but the code still comes up as ignition problem. i'm just curious if tehre is a way to find out if it's the distributor,wires,plugs, coil or whatever. thanks for the help though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjsls »</TD></TR><TR><TD CLASS="quote">well whats the exact code?</TD></TR></TABLE>
PowerHouse... Why don't you tell us what the error code number is? There's several related to ignition...
honda011... What year/version Integra do you have? Look at the sticky thread at the top to see how to read the code.
