90 integra cranks but wont fire
Old Nov 11, 2004 | 01:51 PM
4b1z's Avatar
Default 90 integra cranks but wont fire
I just replaced my old b18 a engine and tranny.New distributor complete,Engine cranks but wont fire.When i take the 1st spark plug out and test it for spark the engine then fires and starts on 3 cylinders ,running very rough.So i think oh it will start now.So i put the plug back in and try to start ,but same problem engine wont fire.I am baffled,any help?I was told to get a new main relay,but that didnt help.Could it be the ignition switch?
Old Nov 11, 2004 | 02:25 PM
The Destroyer's Avatar
Default Re: 90 integra cranks but wont fire (4b1z)
If its getting spark, maybe try adjusting the timing?
Old Nov 11, 2004 | 04:15 PM
Cjsls's Avatar
Default Re: 90 integra cranks but wont fire (Vtaaak y0)
Make sure the spark plug wires on the dizzy are in the right place.
Old Nov 11, 2004 | 05:21 PM
4b1z's Avatar
Default Re: 90 integra cranks but wont fire (Cjsls)
the firing order it shows me in my manual on the dizzy from top left clockwise is- 4-3-2-1 if its wrong let me know.Today i tested the green and yellow wire coming off the dizzy for voltage and i found that with the key in the on position it had voltage but as soon as i turn it over the voltage turns off.Isnt this wrong isnt the green and yellow wire supposed to be on when you turn the car over?
Old Nov 11, 2004 | 07:40 PM
mr.beeks's Avatar
your firing sequence is wrong
1-3-4-2
Old Nov 11, 2004 | 08:06 PM
4b1z's Avatar
Default Re: 90 integra cranks but wont fire (mr.beeks)
From top left of the distributor clockwise its 1,3,4,2?And on the engine it is 4-3-2-1 right? So im an idiot,and my manual is generic.Thanx
Old Nov 11, 2004 | 08:10 PM
mr.beeks's Avatar
number one piston near timming belt and 4 is the one near the distributor.
3-4
1-2
or
1-3
2-4
I get the gsr and ls sequense confused so give it a try.
Old Nov 12, 2004 | 04:10 AM
JimBlake's Avatar
Honda distributor caps are usually marked at #1. Something like "A" molded into the cap? Knowing where #1 is, go clockwise 1 - 3 - 4 - 2.
Old Nov 12, 2004 | 09:06 AM
4b1z's Avatar
Default Re: 90 integra cranks but wont fire (JimBlake)
Im not seeing a spark at the plug when its out and im cranking it.Do i have to ground the plug out?Its i bitch doing this by myself.Thanx for the firing order that always helps
Old Nov 12, 2004 | 10:09 AM
JimBlake's Avatar
In order for the plugs to spark the threaded part (or the wrench-hex) MUST be laying against a good engine ground. If you hold 'em up in the air they won't spark...
hmtcrxsir
Jan 15, 2010 10:59 AM
Mik2006
Jul 31, 2009 02:54 PM
guido45
Feb 1, 2008 06:47 PM
andrew714
Dec 13, 2007 09:35 PM
AIWFCIATR
Jul 23, 2004 11:54 PM
