Worn Piston Rings?
Old Dec 25, 2001 | 04:00 PM
SteelCityKid's Avatar
New User
Default Worn Piston Rings?
I have had a problem losing oil for a while now.
But my question is this- I have noticed after starting the car and giving it some gas, the exhaust "spits" an oily water. It's thin, but dirty. Today I fed it some gas while it was warming and the exhaust spewed out "oil-h20" to reach about 4 feet! Not a puddle - just shot-out liquid.
Is this a sympton of bad rings? If not, what the hell is it?
'95 GS-R 85k
Old Dec 25, 2001 | 04:51 PM
Mr. Softee's Avatar
Default Re: Worn Piston Rings? (SteelCityKid)
my car does this as well.
Old Dec 25, 2001 | 04:53 PM
Mr. Softee's Avatar
Default Re: Worn Piston Rings? (97lstegra)
i dont think its rings, and its not headgasket. i did some tests on my motor and it was neither. im pulling the head ina few weeks to get some further information.
Old Dec 25, 2001 | 08:32 PM
Tweakmeister's Avatar
It's most likely some kind of seal. When was the last time you had a valve adjustment?
Old Dec 25, 2001 | 08:37 PM
Arturbo's Avatar
Better than steak
25 Year Member
I had the same problem with my CRX and I found out that my cam timing was off so the fuel wasnt getting burned and it was coming out of the exhaust. The cam pulleys were off one tooth.
art
Old Dec 25, 2001 | 09:51 PM
Mr. Softee's Avatar
Default Re: Worn Piston Rings? (Arturbo)
can you explain this a little more?
Old Dec 25, 2001 | 11:58 PM
Mista Bone's Avatar
D Tranny Guru
Headgasket or cracked head.
Old Dec 26, 2001 | 03:08 AM
Backyard Speical's Avatar
Default Re: Worn Piston Rings? (Mista Bone)
if you're head gasket is bad or the head is cracked, you're car should over heat.
just a thought.....
Jreycrx
May 19, 2007 09:31 AM
1bar_ek
Apr 17, 2007 10:00 AM
Rxmig7
Jan 10, 2007 08:48 PM
monsterb18b
Aug 21, 2003 01:45 PM
MIDNIGHT
Apr 7, 2002 06:45 PM
